ASR virtual template command "ip idle-group X in" not supported.
ASR 1002-X Version 17.6.2
Unable to use the "ip idle-group X (in|out)" when creating a virtual template on an ASR, this was available on older IOS routers.
Example config:
interface Virtual-Template10
ip idle-group 1 in
ppp timeout idle 60
Access-list 1 permit any
I'm unable to find any documentation for this command within IOS XE or what its replacement is.
This is the documentation to the older IOS guide.
https://www.cisco.com/c/en/us/td/docs/ios/dial/configuration/guide/15_0s/dia_15_0s_book/dia_cust_prf_idle_timer.pdf
0 Replies 0
