How to configure Cisco 4221 WEB UI for WAN Configuration
pravikiran92
can you please help , how can i enable webUi in cisco 4221 router for ISP configure
balaji.bandi
Device #configure terminal
Device (config)# username <username> privilege <privilege> password 0 <passwordtext>
Device (config)#ip http server
Device (config)#ip http secure-server
 Device (config)#ip http authentication loccal
https://ip-address
if this is fresh install you can follow below guide :
https://www.cisco.com/c/en/us/td/docs/routers/access/4400/software/configuration/guide/isr4400swcfg/bm_isr_4400_sw_config_guide_chapter_011.html
Step 1
Configure the HTTP server. By default, the HTTP server configuration should be present on the device. Ensure the configuration by checking if the ip http server and ip http secure-server commands are present in the running configuration.
Step 2
Set up the authentication options to log into Web UI. You can use one of these methods to authenticate:
  1. You can authenticate using local database. To use a local database for Web UI authentication, ensure to have the ip http authentication local command in the running configuration. This command is preconfigured on the device. If the command is not present, configure the device as shown in this example:
     Device (config)#ip http authentication local
  2. Authenticate using AAA options. To use AAA authentication for Web UI, ensure to configure ‘ip http authentication aaa’ on the device. Also, ensure that the required AAA server configuration is present on the device.
Step 3
Launch the browser. In the address bar, type the IP address of the device. For a secure connection, type https://ip-address.
Step 4
Enter the default username (webui) and default password (cisco).
Step 5
Click Log In.
BB
balaji.bandi
https://ip-address
Step 1
Step 2
Step 3
Step 4
Step 5
Click Log In.
BB
pravikiran92
Hi Balaji
Grate awesome , this is worked for me.
One more thing , i have facing one issue after configured.
actually, we have taken 150mbps bandwidth from ISP , it is working direct from ISP Line, but i have getting 2mbps /3mbps through Cisco Router which is configured.
i think missed some configuration , can you please help on this.
Thnx in advance.
