asr Vs isr routers
JATINDER KUMAR
Dear friends,
     can you please xplain me the difference between ASR and ISR touters because we have got ISR 3825 and telecom os proposing us to buy ASR 1004 to terminate lines which is damn costly.. why cant we use 3825 with some modules .. dont know abt ASR please help...
JAtin
sean_evershed
Level 7
Level 7
Are they also proposing that you buy this high end router from them?
I suggest that you consult this link below for the features of the ASR 1004:
http://www.cisco.com/en/US/products/ps9437/index.html
See this link for model comparisons
http://www.cisco.com/en/US/products/ps9343/prod_models_comparison.html
One of the major differences is the speed. The ASR has a throughput of up to 20G. I have read some posts stating that a 3825 only has a throughput of 1G in comparison.
Please remember to rate all posts that are helpful
Hi JAtin,
The Cisco ASR 1002 Fixed Router - delivered performance throughput values greater than the target positioning bandwidth requirements while integrated services features were activated.
And branches with greater bandwidth requirements would use 3925E, 3945E or an ASR 1002.
Please find the attached pdf for the performance lab test between ISR and ASR routers for more information.
Please rate the helpfull posts.
Naidu.
