[ASR1000] Binding Mamanegemnt Interface with Normal Routed Interface
y_ananthan
Dear expert,
Can we binding the management interface with normal routed interface (global Gigabyte interface) ?
If any materials to refer?
Thank you.
-Ananthan
Bilal Nawaz
Hello Ananthan,
I do not think you can. And if you can, I would definitely not recommend it. The purpose of having a management interface was to separate the functions and dedicate it to another VRF purposefully for administering the device.
Here is more information about it. http://www.cisco.com/c/en/us/td/docs/routers/asr1000/configuration/guide/chassis/asrswcfg/Management_Ethernet.html#84585
Hth
Bilal - CCIE #45032
Please rate useful posts & remember to mark any solved questions as answered. Thank you.
