ASR1001 log message SIP0
unfraget
hi everybody.
we have asr1000 with netx configuration and ios version
Chassis type: ASR1001
Slot      Type                State                 Insert time (ago)
0         ASR1001             ok                    1y3w
 0/0      ASR1001             ok                    1y3w
R0        ASR1001             ok, active            1y3w
F0        ASR1001             ok, active            1y3w
P0        ASR1001-PWR-AC      ok                    1y3w
P1        ASR1001-PWR-AC      ok                    1y3w
P2        ASR1001-FANTRAY     ok                    1y3w
Slot      CPLD Version        Firmware Version
0         10042219            15.0(1r)S
R0        10042219            15.0(1r)S
F0        10042219            15.0(1r)S
Cisco IOS XE Software, Version 03.16.05.S - Extended Support Release
Cisco IOS Software, ASR1000 Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 15.5(3)S5, RELEASE SOFTWARE (fc2)
recently  noticed that the following message appear in the log
Nov 22 11:38:59 MSK: %FMFP-3-OBJ_DWNLD_TO_CPP_FAILED: SIP0: fman_fp_image:  Batch type 1 ID 2882382797  download to CPP failed
and then another message
Nov 22 17:03:03 MSK: %CPPOSLIB-3-ERROR_NOTIFY: SIP0: cpp_cp:  cpp_cp encountered an error -Traceback= 1#5ae274d0f1ad03549f3b1851e1a41740   errmsg:7F67D1B9E000+121D cpp_common_os:7F67D5025000+DA3C cpp_common_os:7F67D5025000+1B5AE cpp_ifdb:7F67E8AB7000+82CE cpp_ifdb:7F67E8AB7000+15D9B cpp_qos_ea_lib:7F67E9F3D000+747AA cpp_qos_ea_lib:7F67E9F3D000+73AE9 cpp_common_os:7F67D5025000+11C20 cpp_common_os:7F67D5025000+12306 evlib:7F67D3D97000+B937 evlib:7F67D3D97000+E200 cpp_common_os:7F67D5025000+13E42 :400000+5DB6 c:7
what we can do with this messages and how much the are critical?
5 Replies 5
Mark Elsen
- Although not the same platform it is probably related to bug(s) such as reported in the link below : try more recent software release(s) for your platform, if available and or applicable and  check if the problem persists.
                         https://bst.cloudapps.cisco.com/bugsearch/bug/CSCum98061/?rfs=iqvred
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
also i noticed that features of qos such as policy-route stopped working
 - Bouncing my reply !
    M.
       Beauty and terror
      Just keep going
       No feeling is final
Leo Laohoo
Raise a TAC Case and get them to confirm if you're hitting CSCvc35937.
problem was solved by reboot
