ASR1001-x VLANS on Sub-interfaces
RBrien
We have just installed an ASR1001-x router and need to suport 3 vlans at present
is there any information/documentation on how to do this
At present we have three sub-interfaces on Physical Port G0/0/3 - namely 0/0/3.3, 0/0/3.4 and 0/0/3.5
how do i configure the Physical and Logical ports to comunicate with the LAN and Internet.
Any suggestions or references will be greatly appreciated.
With kind regards, Rob.
Giuseppe Larosa
Hello Rbrien,
you need to associate each subinterface to the desired Vlan id
Example:
int gi0/0/3
no shut
no ip address
int gi0/0/3.3
encapsulation dot1q 30
ip address 10.10.30.1 .255.255.255.0
exit
int gi0/0/3.4
enc dot1q 40
ip address 10.10.40.1 255.255.255.0
exit
int gi0/0/3.5
enc dot1q 50
ip address 10.10.50.1 255.255.255.0
note: usually best practice is to use a subinterface index equal to the Vlan id you want to associate
example
int gi0/0/3.60
enc dot1q 60
This helps in troubleshooting, but the subinterface index can be different then the associated Vlan with the encapsulation command.
The gi0/0/3 port has to be connected to a switch configured as an 802.1Q trunk allowing all necessary Vlans
Example:
int gi0/25
desc to ASR1001 : gi0/0/3
switchport
switchpot mode trunk
switchport trunk allowed vlan 30,40,50
This should allow the new router to act as a router on a stick using subinterfaces and performs inter Vlan routing if required.
For Internet access you will need to use NAT = Network Address translation.
all internal interfaces will have ip nat inside command
int gi0/0/3.x
ip nat inside
the interface to the internet having a public IP address (likely) for example gi0/0/0
will have ip nat outside
int gi0/0/0
desc interface to internet
! public IP address
ip nat outside
Then you will define an access--list like the following
access-list 11 permit 10.10.30.0 0.0.0.255
access-list 11 permit 10.10.40.0 0.0.0.255
access-list 11 permit 10.10.50.0 0.0.0.255
! key command to enable NAT, the overload option is needed to allow multiple internal hosts to access the internet
ip nat inside source list 11 interface gi0/0/0 overload
Note:
the NAT configuration proposed above is a basic setup that works well if you haven't IPSEC VPNs with remote sites and a single exit interface to the internet.
The IPSEC VPN site to site would require NAT to be skipped when an internal LAN speaks to a remote LAN IP subnet.
This would require using an IP extended ACL that can be invoked by a route-map and then using the route-map in the ip nat inside source route-map NAT interface gi0/0/0 overload command.
The IP extended ACLs would contain deny statements for LAN to LAN communications over VPN and then the equivalent of permit statements used in the standard ACL used above.
Hope to help
Giuseppe
Giuseppe Larosa
Hello Rbrien,
Example:
int gi0/0/3
no shut
no ip address
int gi0/0/3.3
exit
int gi0/0/3.4
enc dot1q 40
exit
int gi0/0/3.5
enc dot1q 50
example
int gi0/0/3.60
enc dot1q 60
Example:
int gi0/25
switchport
int gi0/0/3.x
ip nat inside
int gi0/0/0
! public IP address
ip nat outside
Note:
Hope to help
Giuseppe
All fixed thank you
jroy777
I have an ASR 10g interface that is connected to a native vlan1 in a HP switching fabric (8 switches) for databases (inside for ASA), now I want to create a sub interface on that same 10g interface to another set of switches that are also on a separate switch fabric (4 switches) app/web servers dmz on ASA). Currently they talk to each only thru ASA. since both sets of switches are vlan1, how would I do this? The other side of ASR goes to AWS Direct connect environment and we need to move data between Data Center and AWS.
