ASR1002 BGP - High cpu
bozo.bogd
We were planing internet access router migration from some old device to new Cisco ASR1002.
During first attempt of migration we faced an issue with HIGH CPU utilization after first eBGP peering connection established.
Bgp peering loaded full internet routing table (716403) prefix in 3, 3 and a half minutes.
Afterwords CPU shows high "IP RIB Update" for 4-5 minutes and than it calmed down.
Basically it takes 7-8 minutes for one BGP peering to be established and router to be stable and responsive.
Later on we realized that "IP RIB Update" means CEF populating which goes mush slower than BGP routes populating.
Router#show ip cef summary
IPv4 CEF is enabled for distributed and running
VRF Default
 716493 prefixes (716493/0 fwd/non-fwd)
 Table id 0x0
 Database epoch:        2 (716493 entries at this epoch)
We don't expect it to be same speed but this slowness and CPU utilization which makes router almost not responsive is not expected.
For testing purpose we tried simple config in global routing table and VRF, result is the same.
I ll paste version and config, if you can have a look and suggest solution which maybe we have overseen.
Thank you in advance.
isco IOS XE Software, Version 03.16.07b.S - Extended Support Release
Cisco IOS Software, ASR1000 Software (PPC_LINUX_IOSD-ADVENTERPRISEK9-M), Version 15.5(3)S7b, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2018 by Cisco Systems, Inc.
Compiled Fri 02-Mar-18 08:38 by mcpre
Cisco IOS-XE software, Copyright (c) 2005-2018 by cisco Systems, Inc.
All rights reserved.  Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0.  The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY.  You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0.  For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
ROM: IOS-XE ROMMON
Router uptime is 1 day, 21 hours, 34 minutes
Uptime for this control processor is 1 day, 21 hours, 38 minutes
System returned to ROM by reload
System image file is "bootflash:/asr1000rp1-adventerprisek9.03.16.07b.S.155-3.S7b-ext"
Last reload reason: Reload Command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco ASR1002 (2RU) processor (revision 2RU) with 1638738K/6147K bytes of memory.
Processor board ID FOX1413G90A
4 Gigabit Ethernet interfaces
1 Ten Gigabit Ethernet interface
32768K bytes of non-volatile configuration memory.
4194304K bytes of physical memory.
7757823K bytes of eUSB flash at bootflash:.
Building configuration...
Current configuration : 8078 bytes
! Last configuration change at 12:56:27 UTC Mon Dec 3 2018
version 15.5
no platform punt-keepalive disable-kernel-core
hostname Router
boot-start-marker
boot-end-marker
vrf definition INTERNET
 description INTERNET
 rd xxxxx:2
 route-target export xxxxx:2
 route-target import xxxxx:2
 route-target import xxxxx:10014
 route-target import xxxxx:10092
 route-target import xxxxx:10137
 route-target import xxxxx:10145
 route-target import xxxxx:10156
 address-family ipv4
  import map VRF-INTERNET-IMPORT-MAP
 exit-address-family
 address-family ipv6
 exit-address-family
vrf definition Mgmt-intf
 address-family ipv4
 exit-address-family
 address-family ipv6
 exit-address-family
no aaa new-model
subscriber templating
redundancy
 mode none
interface Null0
 no ip unreachables
 no ipv6 unreachables
interface TenGigabitEthernet0/2/0
 ip address 149.x.x.x 255.255.255.252
interface GigabitEthernet0
 vrf forwarding Mgmt-intf
 ip address 10.179.3.9 255.255.255.0
 negotiation auto
router ospf 1
router bgp xxxxx
 bgp router-id x.x.x.x
 no bgp enforce-first-as
 bgp log-neighbor-changes
 bgp maxas-limit 100
 timers bgp 10 30
 neighbor x.x.x.x remote-as xxx
 neighbor x.x.x.x description xxxxxxx
 neighbor x.x.x.x ebgp-multihop 255
 neighbor x.x.x.x password 7 09421B020F2416445C0F2F000C1D3D05673343571A
 neighbor x.x.x.x update-source TenGigabitEthernet0/2/0
 address-family ipv4
  neighbor x.x.x.x activate
  neighbor x.x.x.x prefix-list DENY-ALL out
  neighbor x.x.x.x filter-list 2 out
 exit-address-family
ip forward-protocol nd
ip extcommunity-list standard INTERNET permit rt xxxxx:2
ip extcommunity-list standard INTERNET-VRF permit rt xxxxx:2
ip bgp-community new-format
ip community-list standard TEAM-CYMRU-BOGONS permit 65332:888
ip community-list standard SPAMHAUS-DROP permit 65190:1000
ip community-list standard SPAMHAUS-EDROP permit 65190:2000
ip community-list standard SPAMHAUS-BCL permit 65190:3000
ip community-list standard XXXX-BLACKHOLED-PREFIXES permit 666:666
ip community-list expanded KPN-INTERNET permit xxxxx:21
ip community-list expanded IX-INTERNET permit xxxxx:22
ip community-list expanded ADC-INTERNET permit xxxxx:23
ip community-list expanded BDC-INTERNET permit xxxxx:24
ip as-path access-list 1 permit ^$
ip as-path access-list 2 deny ^$
ip as-path access-list 10 permit ^$
ip as-path access-list 10 permit _203630$
ip as-path access-list 12 permit _5432_
ip as-path access-list 38 permit _3856$
ip as-path access-list 42 permit _42$
ip as-path access-list 84 permit 2484$
ip ftp source-interface Loopback100
no ip http server
no ip http secure-server
ip tftp source-interface Loopback100
no ip route static inter-vrf
ip route vrf Mgmt-intf 0.0.0.0 0.0.0.0 10.179.3.1
ip prefix-list BGP-ADVERTISE-FROM-INET-TO-RR-CLIENTS description FILTER PREFIXES TO BE ADVERTISED FROM THE INTERNET TO RR CLIENTS
ip prefix-list BGP-ADVERTISE-FROM-INET-TO-RR-CLIENTS seq 5 permit 0.0.0.0/0
ip prefix-list DEFAULT-ROUTE-ONLY description ONLY ALLOW DEFAULT ROUTE
ip prefix-list DEFAULT-ROUTE-ONLY seq 5 permit 0.0.0.0/0
ip prefix-list DENY-ALL description BLOCK ALL PREFIXES
ip prefix-list DENY-ALL seq 5 deny 0.0.0.0/0 le 32
ip prefix-list TEAM-CYMRU-BOGON-FILTER-IN description RESTRICT CERTAIN PREFIXES INBOUND FROM CYMRU PEERINGS
ip prefix-list TEAM-CYMRU-BOGON-FILTER-IN seq 5 deny 0.0.0.0/0
ip prefix-list TEAM-CYMRU-BOGON-FILTER-IN seq 15 permit 0.0.0.0/0 le 32
ip prefix-list VRF-INTERNET-IMPORT-PREFIXES description ALLOW INTERNET PREFIXES FROM CUSTOMER VRFs
control-plane
end
6 Replies 6
Joseph W. Doherty
On the ASR, your BGP peering setup might be sped up by enabling PMTUD and also by setting the router's host RWIN to at least 64KB (NB: this assuming the defaults don't enable or have lower values).
As to an ASRs high CPU during initial BGP peering, that might be because the ASRs generally have "special" hardware to improve data plane performance, but it may depend solely on the CPU for control plane. (I believe the ASRs might be much, in general architecture concept, like the earlier 7300 with a NSE or 7200 with the NSE-1.)
Dear Joseph,
PMTUD didn't brought any difference.
You also adjusted the router's TCP RWIN?
Yes, I did. No differences
on a side note, you seem to have an empty OSPF process running ('router ospf 1'), can you remove that ?
Yes i can, but that doesn't make any difference still.
