02-22-2022 06:24 AM
Greetings.
Trying to upgrade ASR1002-RP1 rommon with no success.
Installed IOS ADVENTERPRISEK9-M), Version 15.5(3)S10,
Now installed 16.3(2r)
Slot CPLD Version Firmware Version --------- ------------------- --------------------------------------- 0 07120202 16.3(2r) R0 08011017 16.3(2r) F0 07091401 16.3(2r)
Upgrading with
#upgrade rom-monitor filename bootflash:asr1000-rommon.173-1r.SPA.pkg all
Upgrade rom-monitor on Route-Processor 0
Target copying rom-monitor image file
1966080+0 records in
1966080+0 records out
Checking upgrade image...
ROMMON upgrade complete.
To make the new ROMMON permanent, you must restart the RP.
Same also with Embedded-Service-Processor 0 & SPA-Inter-Processor 0
On the next reboot its
#reload
Proceed with reload? [confirm]
Feb 22 15:25:23.175 R0/0: %PMAN-5-EXITACTION: Process man
System Bootstrap, Version 16.3(2r), RELEASE SOFTWARE
Copyright (c) 1994-2016 by cisco Systems, Inc.
Current image running: Boot ROM1
Last reset cause: LocalSoft
Last reset at: Tue Feb 22 12:25:40 UTC 2022
ASR1002-RP1 platform with 4194303 Kbytes of main memory
Rommon upgrade requested
Flash upgrade reset 1 in progress
Current image running: *Upgrade in progress* Boot ROM0
Last reset cause: BootRomUpgrade
Last reset at: Tue Feb 22 12:25:58 UTC 2022
ROMmon still stay 16.3(2r),
Also try to upbgade step by step with hw-module slot reload - no effect.
Is there an issue ?
02-22-2022 10:21 AM
looks like you are doing it by the book...
Can you post the output of:
show platform
dir bootflash
02-22-2022 10:54 AM - edited 02-22-2022 10:56 AM
#sh platform
Chassis type: ASR1002
Slot Type State Insert time (ago)
0 ASR1002-SIP10 ok 05:52:32 0/0 4XGE-BUILT-IN ok 05:48:28 0/1 SPA-1X10GE-L-V2 ok 05:48:28 0/2 SPA-1X10GE-L-V2 ok 05:48:29 0/3 SPA-5X1GE-V2 ok 05:48:25R0 ASR1002-RP1 ok, active 05:52:32F0 ASR1000-ESP10 ok, active 05:52:32P0 ASR1002-PWR-AC ok 05:50:06P1 ASR1002-PWR-AC ok 05:50:03Slot CPLD Version Firmware Version
0 07120202 16.3(2r)
dir bootflash:
Directory of bootflash:/
11 drwx 16384 Apr 26 2011 14:49:11 +03:00 lost+found
12 -rw- 6662 Jun 28 2011 13:22:42 +03:00 cfg_backup
15 -rw- 8133 Aug 5 2011 14:11:59 +03:00 bgp
162561 drwx 4096 Apr 26 2011 14:50:23 +03:00 .installer
764033 drwx 4096 Dec 25 2017 05:39:33 +03:00 core
178817 drwx 4096 Feb 22 2022 15:41:40 +03:00 .prst_sync
666497 drwx 4096 Apr 26 2011 15:21:22 +03:00 .rollback_timer
13 -rw- 0 Apr 26 2011 15:21:54 +03:00 tracelogs.781
146305 drwx 24576 Feb 22 2022 15:49:42 +03:00 tracelogs
14 -rw- 395158140 Feb 14 2019 17:38:14 +03:00 asr1000rp1-adventerprisek9.03.16.08.S.155-3.S8-ext.bin
16 -rw- 35 Feb 21 2022 16:42:23 +03:00 pnp-tech-time
17 -rw- 17296 Feb 21 2022 16:42:28 +03:00 pnp-tech-discovery-summary
19 -rw- 395094652 Feb 22 2022 13:26:16 +03:00 asr1000rp1-adventerprisek9.03.16.10.S.155-3.S10-ext.bin
18 -rw- 2537776 Dec 17 2013 22:34:19 +03:00 asr1000-rommon.153-3r.S.pkg
23 -rw- 41059376 Feb 22 2022 13:28:21 +03:00 asr1000-rommon.173-1r.SPA.pkg
20 -rw- 394965628 Dec 25 2017 01:42:24 +03:00 asr1000rp1-adventerprisek9.03.16.06b.S.155-3.S6b-ext.bin
21 -rw- 7302104 Dec 25 2017 01:44:33 +03:00 asr1000-rommon.163-2r.pkg
7860539392 bytes total (6203289600 bytes free)
02-22-2022 02:28 PM
What is the intention of using 17.3.1r?
I recently deployed an ASR-1002 (RP1) and the router is running on 3.16.10 (Install Mode) but I refused to upgrade the ROMMON. The ROMMON is currently on 16.3.2r.
Chassis type: ASR1002 Slot Type State Insert time (ago) --------- ------------------- --------------------- ----------------- 0 ASR1002-SIP10 ok 11w6d 0/0 4XGE-BUILT-IN ok 11w6d R0 ASR1002-RP1 ok, active 11w6d F0 ASR1000-ESP5 ok, active 11w6d P0 ASR1002-PWR-AC ok 11w6d P1 ASR1002-PWR-AC ok 11w6d Slot CPLD Version Firmware Version --------- ------------------- --------------------------------------- 0 07120202 16.3(2r) R0 08011017 16.3(2r) F0 07091401 16.3(2r)
02-22-2022 03:01 PM
I've always run a lates soft on my deployments , to get an actual fixes. That's why.
There was no trouble in a few past upgrades on that device.
Now I'm stuck cause can't find any reason , why upgrade falls.
No boot errors , no log warnings , can't find any restrictions for upgrading RP1 platform, especially it's available for download in ASR1K download section, just like 16.3(2r)
Just one difference - is SPA in 17.3.1 name - maybe that's a key ?
02-22-2022 04:22 PM
The reason why I did not upgrade to 17.3.1r is because I have seen people run into problems.
My recommendation is to just stay with 16.3.(2r) and it will be fine.
