Hi Team,
I am running ASR1002 with latest XE IOS version asr1000rp1-adventerprisek9.03.02.01.S.151-1.S1.bin
configuration bellow
router bgp 65000
bgp router-id 1.1.1.1
bgp log-neighbor-changes
timers bgp 5 15
address-family ipv4 vrf LABR01-VRF
neighbor bgprrclient peer-group
neighbor bgprrclient remote-as 65001
neighbor bgprrclient password 7 1234
neighbor bgprrclient update-source Loopback0
neighbor bgprrclient version 4
neighbor bgprrclient route-reflector-client
neighbor bgprrclient route-map set_weight in
I then tried to create new route-map and get error that match next-hop can not be used on inbound
route-map set_weight permit 10
match ip next-hop prefix-list thirdparty
match as-path 1
set weight 1000
LAB-ASR1002(config)#route-map set_weight permit 10
LAB-ASR1002(config-route-map)# match ip next-hop prefix-list thirdparty
% "set_weight" used as BGP inbound route-map, nexthop match not supported
% not supported match will behave as route-map with no match
Not sure why Cisco is not supporting a pretty basic feature for BGP route maps.
I tried looking into matching other variables but I am unable to get same result as I have same routes on bgp table from multible inbound peers.
I also get this message when configuring tacacs. I looked for "new" cli but no luck:
LAB-ASR1002(config)#tacacs-server host 2.2.2.2
This cli will be deprecated soon. Use new server cli
Any ideas how to get around this two issues?
Many thanks
Gonz.
