01-28-2011 12:46 AM - edited 03-04-2019 11:14 AM
The loopback of the ASR1002 is 2.2.2.2.
When I use a browser to access it, I got the authentication dialog box asking for username/password. I input the information and submit. But authentication box comes back again and ask for the username/password.
The username/password is test okay. But somehow, the web GUI just does not use it.
Any idea?
Thanks!
Solved! Go to Solution.
02-02-2011 01:00 AM
...have you tried to adapt the http config using the IOS command below, to use local username and password for authentication?
ip http authentication local
and is the local username configured with the privilege level 15, like this for example?
username cisco privilege 15 cisco
02-02-2011 01:00 AM
02-06-2011 06:39 PM
Thanks for the advise and I think it will fix the issue.
