ASR1002-X - L2TP Tunnels up but no Ping !
manu782623
we are testing an ASR1002-X which acts as LNS for L2TP tunnels.
- All tunnels are UP (sh vpdn all return list of tunnels)
- VirtualAccess interfaces are UP
- C routes are added in routing table
but ping remote IPs  don't work !!!
Here technical information. Thanks a lot for help !
Manuel
LNS1# sh ver
Cisco IOS Software, IOS-XE Software (X86_64_LINUX_IOSD-UNIVERSAL-M), Version 15.3(2)S1, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2013 by Cisco Systems, Inc.
Compiled Mon 27-May-13 13:56 by mcpre
IOS XE Version: 03.09.01.S
ROM: IOS-XE ROMMON
LNS uptime is 1 day, 11 hours, 57 minutes
Uptime for this control processor is 1 day, 11 hours, 59 minutes
System returned to ROM by reload
System image file is "bootflash:asr1002x-universal.03.09.01.S.153-2.S1.SPA.bin"
Last reload reason: Reload Command
License Level: ipbase
License Type: Permanent
Next reload license Level: ipbase
cisco ASR1002-X (2RU-X) processor with 1151339K/6147K bytes of memory.
Processor board ID SSI16450ENF
6 Gigabit Ethernet interfaces
32768K bytes of non-volatile configuration memory.
4194304K bytes of physical memory.
6684671K bytes of eUSB flash at bootflash:.
LNS1#  show caller user login@domain.tdr
  User: login@domain.tdr, line Vi2.13, service PPPoVPDN
        Connected for 00:04:43
  Timeouts:    Limit     Remaining Timer Type
               1d06h     1d05h     Session
  PPP: LCP Open, CHAP (<-), IPCP
  IP: Local W.X.Y.254, remote W.X.Y.17
  Counts: 69 packets input, 960 bytes
          73 packets output, 1026 bytes
LNS1# show interfaces virtual-access 2.13
Virtual-Access2.13 is up, line protocol is up
  Hardware is Virtual Access interface
  Interface is unnumbered. Using address of Loopback0 (W.X.Y.254)
  MTU 1460 bytes, BW 1000000 Kbit/sec, DLY 100000 usec,
  Encapsulation PPP, LCP Open
  Open: IPCP
  PPPoVPDN vaccess, cloned from Virtual-Template1
  Vaccess status 0x0
  Protocol l2tp, tunnel id 16822, session id 65182
  Keepalive set (10 sec)
     71 packets input, 988 bytes
     75 packets output, 1054 bytes
  Time to interface disconnect:  absolute 1d05h
LNS1# show interfaces virtual-access 2.13 configuration
Virtual-Access2.13 is an VPDN link (sub)interface
Derived configuration : 378 bytes
interface Virtual-Access2.13
mtu 1460
ip unnumbered Loopback0
ip nat inside
ip tcp adjust-mss 1420
ip policy route-map INTERNET_VT1
timeout absolute 1800 0
no peer default ip address
ppp authentication chap pap DSL-AAA
ppp authorization DSL-AAA
ppp accounting DSL-AAA
ppp ipcp address required
ppp ipcp address accept
ip virtual-reassembly
end
LNS1#sh ip route
C        W.X.Y.20/32 is directly connected, Virtual-Access2.13
C        W.X.Y.21/32 is directly connected, Virtual-Access2.15
C        W.X.Y.22/32 is directly connected, Virtual-Access2.34
C        W.X.Y.23/32 is directly connected, Virtual-Access2.23
C        W.X.Y.24/32 is directly connected, Virtual-Access2.46
C        W.X.Y.28/32 is directly connected, Virtual-Access2.50
C        W.X.Y.30/32 is directly connected, Virtual-Access2.67
C        W.X.Y.31/32 is directly connected, Virtual-Access2.39
LNS1#show vpdn tunnel all
L2TP Tunnel Information Total tunnels 5 sessions 81
Tunnel id 16822 is up, remote id is 13259, 47 active sessions
  Remotely initiated tunnel
  Tunnel state is established, time since change 01:11:58
  Tunnel transport is UDP (17)
  Remote tunnel name is lac-01
    Internet Address A.B.C.D, port 1701
  Local tunnel name is LNS1
    Internet Address W.X.Y.254, port 1701
  L2TP class for tunnel is LNS
  Counters, taking last clear into account:
    39629 packets sent, 39398 received
    561488 bytes sent, 557740 received
  Last clearing of counters never
  Counters, ignoring last clear:
  Control Ns 119, Nr 103
  Local RWS 1024 (default), Remote RWS 64
  Control channel Congestion Control is disabled
  Tunnel PMTU checking disabled
  Retransmission time 1, max 1 seconds
  Unsent queuesize 0, max 0
  Resend queuesize 0, max 4
  Total resends 0, ZLB ACKs sent 52
  Total out-of-order dropped pkts 0
  Total out-of-order reorder pkts 0
  Total peer authentication failures 0
  Current no session pak queue check 0 of 5
  Retransmit time distribution: 0 0 0 0 0 0 0 0 0
  Control message authentication is disabled
  VPDN group for tunnel is LNS
manu782623
any idea ? Thanks..
Manuel
