ASR1002-X with SFP-GE-T
tvtdbaeza
Hi all,
We are trying to connect an ASR1002-X with 6 SFP-GE-T to a C3750 Switch but the interface never came up in the ASR. They do in the C3750.
The SFP we are using are CISCO-FINISAR
The interfaces are configured in both sides with no negotiation auto and with speed 1000 and duplex full.
I've tested the SFP-GE-T from C3750 to C3750 and they work as spected.
I've googled around and, as far I can see many people with the same or very similar problem, no one have an answer for that.
Here is an output for the interfaces of ASR(0/0/0) and C3750 (1/0/1) that are connected to eachother.
GigabitEthernet0/0/0 is down, line protocol is down
   Hardware is 6XGE-BUILT-IN, address is f07f.06d9.c000 (bia f07f.06d9.c000)
   MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
   Keepalive not supported
   Full Duplex, 1000Mbps, link type is force-up, media type is T
   output flow-control is on, input flow-control is on
   Last input never, output never, output hang never
   Last clearing of "show interface" counters 04:04:41
   Input queue: 0/375/0/0 (size/max/drops/flushes); Total output drops: 0
   Queueing strategy: fifo
   Output queue: 0/40 (size/max)
      0 packets input, 0 bytes, 0 no buffer
      Received 0 broadcasts (0 IP multicasts)
      0 watchdog, 0 multicast, 0 pause input
      0 packets output, 0 bytes, 0 underruns
      0 output errors, 0 collisions, 18 interface resets
      0 unknown protocol drops
      0 lost carrier, 0 no carrier, 0 pause output
C3750-Core(config-if)#do show int gi1/0/1
GigabitEthernet1/0/1 is up, line protocol is up (connected)
   Hardware is Gigabit Ethernet, address is 0012.7f03.eb81 (bia
0012.7f03.eb81)
   MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
   Keepalive set (10 sec)
   Full-duplex, 1000Mb/s, media type is 10/100/1000BaseTX
   input flow-control is on, output flow-control is unsupported
   Last input never, output 00:00:00, output hang never
      Received 0 broadcasts (0 multicasts)
      5579 packets output, 448107 bytes, 0 underruns
      0 output errors, 0 collisions, 11 interface resets
Also, the output for sh hw-module subslot 0/0 transceiver 0 idprom brief
IDPROM for transceiver GigabitEthernet0/0/0:
  Description                               = SFP or SFP+ optics (type 3)
  Transceiver Type:                         = GE T (26)
  Product Identifier (PID)                  = N/A
  Vendor Revision                           = A0
  Serial Number (SN)                        = MTC164805GW
  Vendor Name                               = CISCO-FINISAR
  Vendor OUI (IEEE company ID)              = 00.90.65 (36965)
  CLEI code                                 =
  Cisco part number                         =
  Device State                              = Enabled.
  Date code (yy/mm/dd)                      = 14/09/15
  Connector type                            = LC.
  Encoding                                  = 8B10B
                                              NRZ
  Nominal bitrate                           = GE (1300 Mbits/s)
  Minimum bit rate as % of nominal bit rate = not specified
  Maximum bit rate as % of nominal bit rate = not specified
Any help?
Thanks in advance
tvtdbaeza
Ok, nevermind, is a know bug.
FYI: https://tools.cisco.com/bugsearch/bug/CSCud29930/?referring_site=bugqvinvisibleredir
