12-17-2020 12:20 AM
HI Dear Friend
My ASR1002X After Work in 1 month Get error Low memory And Crash
(not enough memory to log snmp-ma trace)
startup-config file open failed (Not enough space)
My bootflash:
5614579712 bytes available (694415360 bytes used
How solve this ?????
12-17-2020 02:11 AM
Either reboot the router or upgrade the firmware.
12-17-2020 05:39 AM
good luck with that? - may be worth a read - here
12-17-2020 11:16 AM
The interesting discussion to which @paul driver refers was for 1001 (not X as far as we can tell) which was deployed in 2011. This discussion appears to be about 1002X and the mention in the original post about it had been running 1 month suggests that it is a more recent deployment. But we do not know much of anything about this situation. A good starting point would be a show version taken after a reboot of the router.
The error message posted about not enough memory certainly suggest something like a memory leak may be involved. If there is an active maintenance contract for this router then a case with Cisco TAC and/or a different version of code would certainly be in order.
