ASR1002x
Kris Wolton
I have been dumped with an ASR to do some very basic config on, i am slowing getting it done with the CLI, however i would be much more confident with a GUI. Is there one? if so what is it called? I know the Cisco Configuration Professional product will do some of it, but it's been discontinued and does not support half the functions.
Thanks in advance.
Kris
Pranay Prasoon
Level 3
Level 3
You can use CSM. They support ASR routers , for more information please see
http://www.cisco.com/c/en/us/td/docs/security/security_management/cisco_security_manager/security_manager/4-8/compatibility/information/csmsd480.html
Pranay Prasoon
Level 3
Level 3
