BGP and EIGRP redistibution issue
Mylancognizant1
We faced an issue for BGP and EIGRP redistribution issue.
Need to find the route cause and issue here.
what we can do to avoid this..
Please find the logs.
e status down
2015 May  2 06:39:47 MGW-CF-7K01-CORE1 %BGP-5-ADJCHANGE:  bgp-64671 [5193] (default) neighbor 172.26.1.1 Down - holdtimer expired error
2015 May  2 06:39:48 MGW-CF-7K01-CORE1 %BGP-5-ADJCHANGE:  bgp-64671 [5193] (default) neighbor 172.26.1.5 Down - holdtimer expired error
2015 May  2 06:39:51 MGW-CF-7K01-CORE1 %BGP-5-ADJCHANGE:  bgp-64671 [5193] (default) neighbor 172.26.1.6 Down - holdtimer expired error
2015 May  2 06:39:52 MGW-CF-7K01-CORE1 %BGP-5-ADJCHANGE:  bgp-64671 [5193] (default) neighbor 172.26.1.4 Down - holdtimer expired error
2015 May  2 06:39:54 MGW-CF-7K01-CORE1 %BGP-5-ADJCHANGE:  bgp-64671 [5193] (default) neighbor 172.26.1.220 Down - holdtimer expired error
2015 May  2 08:01:05 MGW-CF-7K01-CORE1 %BGP-5-ADJCHANGE:  bgp-64671 [5193] (default) neighbor 172.16.35.85 Down - bfd session down
2015 May  2 08:01:05 MGW-CF-7K01-CORE1 %BFD-5-SESSION_STATE_DOWN: BFD session 1107296257 to neighbor 172.16.35.85 on interface Eth3/6 has gone down. Reason: 0x2.
2015 May  2 08:01:06 MGW-CF-7K01-CORE1 %BFD-5-SESSION_REMOVED: BFD session to neighbor 172.16.35.85 on interface Eth3/6 has been removed
2015 May  2 08:01:16 MGW-CF-7K01-CORE1 %BGP-5-ADJCHANGE:  bgp-64671 [5193] (default) neighbor 172.16.35.85 Up
2015 May  2 08:01:17 MGW-CF-7K01-CORE1 %BFD-5-SESSION_MOVED: BFD session 0x42000002: Installed on LC 3
2015 May  2 08:01:17 MGW-CF-7K01-CORE1 %BFD-5-SESSION_CREATED: BFD session to neighbor 172.16.35.85 on interface Eth3/6 has been created
2015 May  2 08:01:20 MGW-CF-7K01-CORE1 %BFD-5-SESSION_ACTIVE_PARAMS_CHANGE: Local parameter of BFD session 0x42000002 has changed Disc 0x42000002 [[1 if Eth3/6 0x1a1050
00 iod 0x86 562310ac:0:0:0=172.16.35.86 -> 552310ac:0:0:0=172.16.35.85]] TX(2000000): RX(2000000): ST(2000000), Mult(3), Ver(1)
2015 May  2 08:01:20 MGW-CF-7K01-CORE1 %BFD-5-SESSION_STATE_UP: BFD session 1107296258 to neighbor 172.16.35.85 on interface Eth3/6 is up.
2015 May  2 08:01:23 MGW-CF-7K01-CORE1 %BFD-5-SESSION_ACTIVE_PARAMS_CHANGE: Local parameter of BFD session 0x42000002 has changed Disc 0x42000002 [[1 if Eth3/6 0x1a1050
2015 May  2 09:01:12 MGW-CF-7K01-CORE1 %VSHD-5-VSHD_SYSLOG_CONFIG_I: Configured from vty by superadmin on 172.20.72.252@pts/3
2015 May  2 09:14:08 MGW-CF-7K01-CORE1 %VSHD-5-VSHD_SYSLOG_CONFIG_I: Configured from vty by superadmin on 172.16.35.85@pts/0
2015 May  2 10:57:12 MGW-CF-7K01-CORE1 %EIGRP-5-NBRCHANGE_DUAL:  eigrp-200 [5191] (default-base) IP-EIGRP(0) 200: Neighbor 172.26.150.174 (Ethernet3/7) is up: new adjac
ency
2015 May  2 11:36:15 MGW-CF-7K01-CORE1 %VSHD-5-VSHD_SYSLOG_CONFIG_I: Configured from vty by superadmin on 172.20.84.30@pts/2
2015 May  2 12:13:47 MGW-CF-7K01-CORE1 %VSHD-5-VSHD_SYSLOG_CONFIG_I: Configured from vty by superadmin on 172.20.84.32@pts/0
2015 May  2 13:06:37 MGW-CF-7K01-CORE1 %VSHD-5-VSHD_SYSLOG_CONFIG_I: Configured from vty by superadmin on 172.20.84.30@pts/6
2015 May  2 13:26:31 MGW-CF-7K01-CORE1 last message repeated 1 time
2015 May  2 14:13:52 MGW-CF-7K01-CORE1 %VSHD-5-VSHD_SYSLOG_CONFIG_I: Configured from vty by superadmin on 172.20.84.32@pts/0
2015 May  2 14:38:16 MGW-CF-7K01-CORE1 %BGP-5-ADJCHANGE:  bgp-64671 [5193] (default) neighbor 172.16.35.85 Down - bfd session down
2015 May  2 14:38:16 MGW-CF-7K01-CORE1 %BFD-5-SESSION_STATE_DOWN: BFD session 1107296258 to neighbor 172.16.35.85 on interface Eth3/6 has gone down. Reason: 0x2.
2015 May  2 14:38:17 MGW-CF-7K01-CORE1 %BFD-5-SESSION_REMOVED: BFD session to neighbor 172.16.35.85 on interface Eth3/6 has been removed
2015 May  2 14:38:28 MGW-CF-7K01-CORE1 %EIGRP-5-NBRCHANGE_DUAL:  eigrp-200 [5191] (default-base) IP-EIGRP(0) 200: Neighbor 172.26.150.174 (Ethernet3/7) is down: holding
 time expired
2015 May  2 17:49:54 MGW-CF-7K01-CORE1 %BGP-5-ADJCHANGE:  bgp-64671 [5193] (default) neighbor 172.26.1.6 Up
2015 May  2 17:49:58 MGW-CF-7K01-CORE1 %BGP-5-ADJCHANGE:  bgp-64671 [5193] (default) neighbor 172.26.1.5 Up
2015 May  2 17:50:19 MGW-CF-7K01-CORE1 %ETHPORT-5-SPEED: Interface Ethernet4/5, operational speed changed to 10 Gbps
2015 May  2 17:50:19 MGW-CF-7K01-CORE1 %ETHPORT-5-IF_DUPLEX: Interface Ethernet4/5, operational duplex mode changed to Full
2015 May  2 17:50:19 MGW-CF-7K01-CORE1 %ETHPORT-5-IF_RX_FLOW_CONTROL: Interface Ethernet4/5, operational Receive Flow Control state changed to off
2015 May  2 17:50:19 MGW-CF-7K01-CORE1 %ETHPORT-5-IF_TX_FLOW_CONTROL: Interface Ethernet4/5, operational Transmit Flow Control state changed to off
2015 May  2 17:50:19 MGW-CF-7K01-CORE1 %ETHPORT-5-IF_UP: Interface Ethernet4/5 is up in Layer3
2015 May  2 17:50:19 MGW-CF-7K01-CORE1 %ETHPORT-5-IF_DOWN_LINK_FAILURE: Interface Ethernet4/5 is down (Link failure)
2015 May  2 17:50:35 MGW-CF-7K01-CORE1 %BGP-5-ADJCHANGE:  bgp-64671 [5193] (default) neighbor 172.16.35.85 Up
2015 May  2 17:50:36 MGW-CF-7K01-CORE1 %BFD-5-SESSION_MOVED: BFD session 0x42000003: Installed on LC 3
2015 May  2 17:50:36 MGW-CF-7K01-CORE1 %BFD-5-SESSION_CREATED: BFD session to neighbor 172.16.35.85 on interface Eth3/6 has been created
2015 May  2 17:50:39 MGW-CF-7K01-CORE1 %BFD-5-SESSION_ACTIVE_PARAMS_CHANGE: Local parameter of BFD session 0x42000003 has changed Disc 0x42000003 [[1 if Eth3/6 0x1a1050
2015 May  2 17:50:39 MGW-CF-7K01-CORE1 %BFD-5-SESSION_STATE_UP: BFD session 1107296259 to neighbor 172.16.35.85 on interface Eth3/6 is up.
2015 May  2 17:50:41 MGW-CF-7K01-CORE1 %BFD-5-SESSION_ACTIVE_PARAMS_CHANGE: Local parameter of BFD session 0x42000003 has changed Disc 0x42000003 [[1 if Eth3/6 0x1a1050
2015 May  2 17:51:18 MGW-CF-7K01-CORE1 %ETHPORT-5-SPEED: Interface Ethernet4/5, operational speed changed to 10 Gbps
2015 May  2 17:51:18 MGW-CF-7K01-CORE1 %ETHPORT-5-IF_DUPLEX: Interface Ethernet4/5, operational duplex mode changed to Full
2015 May  2 17:51:18 MGW-CF-7K01-CORE1 %ETHPORT-5-IF_RX_FLOW_CONTROL: Interface Ethernet4/5, operational Receive Flow Control state changed to off
2015 May  2 17:51:18 MGW-CF-7K01-CORE1 %ETHPORT-5-IF_TX_FLOW_CONTROL: Interface Ethernet4/5, operational Transmit Flow Control state changed to off
2015 May  2 17:51:18 MGW-CF-7K01-CORE1 %ETHPORT-5-IF_UP: Interface Ethernet4/5 is up in Layer3
2015 May  2 17:51:18 MGW-CF-7K01-CORE1 %EIGRP-5-NBRCHANGE_DUAL:  eigrp-200 [5191] (default-base) IP-EIGRP(0) 200: Neighbor 172.26.150.138 (Ethernet4/5) is up: new adjac
ency
2015 May  2 17:51:23 MGW-CF-7K01-CORE1 %BGP-5-ADJCHANGE:  bgp-64671 [5193] (default) neighbor 172.26.1.1 Up
2015 May  2 17:51:27 MGW-CF-7K01-CORE1 %BGP-5-ADJCHANGE:  bgp-64671 [5193] (default) neighbor 172.26.1.4 Up
2015 May  2 17:51:38 MGW-CF-7K01-CORE1 %ETHPORT-5-SPEED: Interface Ethernet3/5, operational speed changed to 10 Gbps
2015 May  2 17:51:38 MGW-CF-7K01-CORE1 %ETHPORT-5-IF_DUPLEX: Interface Ethernet3/5, operational duplex mode changed to Full
2015 May  2 17:51:38 MGW-CF-7K01-CORE1 %ETHPORT-5-IF_RX_FLOW_CONTROL: Interface Ethernet3/5, operational Receive Flow Control state changed to off
2015 May  2 17:51:38 MGW-CF-7K01-CORE1 %ETHPORT-5-IF_TX_FLOW_CONTROL: Interface Ethernet3/5, operational Transmit Flow Control state changed to off
2015 May  2 17:51:38 MGW-CF-7K01-CORE1 %ETHPORT-5-IF_UP: Interface Ethernet3/5 is up in Layer3
2015 May  2 17:51:42 MGW-CF-7K01-CORE1 %EIGRP-5-NBRCHANGE_DUAL:  eigrp-200 [5191] (default-base) IP-EIGRP(0) 200: Neighbor 172.26.150.78 (Ethernet3/5) is up: new adjace
ncy
2015 May  2 17:51:43 MGW-CF-7K01-CORE1 %BGP-5-ADJCHANGE:  bgp-64671 [5193] (default) neighbor 172.26.1.220 Up
MGW-CF-7K01-CORE1#
Kindly reply
0 Replies 0
