asr1004 ios upgrade site
julxu
I have just got a ASR1004 and try to upgrade it, but, I can not find the instruction, could anyone give me advice/
I guess it may just same as other production by copy. but, it is good to see in writing.
Any comments will be appreciated
thanks in advance
julxu
Bilal Nawaz
Hello, I have never used the high availability features and have always upgraded my ASR 1k's using the IOS upgrade procedure. The thing that might be different in the ASR is the
Ip tftp source
command which caught me out the first time I upgraded the image. Then you need upload the image via tftp or another transfer protocol, make sure the confreg is fine, also the 'boot' command to specify which file you want to boot from.
Conf t
Ip tftp source gi0/0/1
End
Copy tftp flash
Source:10.0.0.100
Source filename: Asr1k.bin
Destination filename: Asr1k.bin
Conf t
Boot system flash:Asr1k.bin
Config-reg 0x2102
End
Copy run start
Reload
Hope this helps
More info here: http://www.cisco.com/en/US/docs/routers/asr1000/configuration/guide/chassis/issu.html#wp1152341
http://www.cisco.com/en/US/docs/routers/asr1000/configuration/guide/chassis/appendixb.html
Please rate useful posts & remember to mark any solved questions as answered. Thank you.
Bilal Nawaz
Ip tftp source
Conf t
End
Copy tftp flash
Source:10.0.0.100
Conf t
Config-reg 0x2102
End
Copy run start
Reload
Hope this helps
Bilal and expert
thanks for the inforamtion, I have ASR1004, the ISSU command do not be supported. so it looks like I need go though all the 20 steps to upgrade the all the subsystems.
However, I seems do not know where to download all the subsystems the doc required.
when I go to cisco support page for download asr1000 images, it only give me the main image, not all the subsystems.
could anyone advice me where to download the pkgs?
Please advice
Thansounds thanks
Julxu
