ASR1004 - QoS - Match Protocol command
David Salazar
If I want to use the command match protocol xxxx  when configuring  traffic classification for QoS, is necessary to have the following licence?
FLASR1-FPI-RTU
Flexible Packet Inspection RTU Feature License for Cisco ASR 1000 Series
http://www.cisco.com/en/US/prod/collateral/routers/ps9343/qa_c67-452124.html
The question is because I was read the following article
Network Security Features for Cisco ASR 1000 Series Routers
http://www.cisco.com/en/US/prod/collateral/routers/ps9343/data_sheet__network_security_features_for_cisco_asr_1000_series_routers.ht
in table 1 say:
Table 1. Security Feature Licenses for Cisco ASR 1000 Series Routers
Features
Feature License Required
IPsec, Easy VPN, DMVPN, Voice and Video Enabled VPN (V3PN), Virtual Tunnel Interface (VTI), secure provisioning and digital certificates, IPsec High Availability, and Cisco IOS Software Certificate Server
FLASR1-IPSEC-RTU
Cisco IOS Firewall and Firewall High Availability
FLASR1-FW-RTU
NBAR and FPM
FLASR1-FPI-RTU
I was read that NBAR permit the use of match protocol command, then is necesary this licence?
Thanks a lot
xabrouck
NBAR should work without license on the 1004.  Those licenses are for the ASR1001 only currently. The 1001 is the only model using the universal(k9) feature set. The 1004 is using the classical feature sets (ipservices, enterprise, ...)
Xavier
