ASR901 Password Reset
Matthew McComb
Is there any way to recover password on ASR901?
Evan Roggenkamp
Bump!
Someone please respond!
I have tried booting up the router and sending the "break" command from both PUTTY and TeraTerm Pro to no avail.
I have also tried the "trick" of setting the baud rate to very low (110), power-cycling and tapping space bar repeatedly to send the break signal. I can not get into rommon mode. The official configuration guide has no information for me either.
Does anyone know the secret?
try ctrl + c
Hello Narinder
You have the trick! Seems to have put me into rommon on my 901.
Many thanks to you!
