ASR903 netflow/flexible netflow support
m.yamaguchi
Hi All,
We would like to clarify one doubt about ASR903 routers: Does it have support for netflow/flexible netflow?
We are trying to configure this netflow/flexible netflow but it is not working properly on this platform. On ASR1000 platform the same config is working properly.
Follow device's show version info:
------------------ show version ---------------------------------------------------------------------------------------------------------------------------------------------------
Cisco IOS XE Software, Version 03.11.01.S - Standard Support Release
Cisco IOS Software, ASR903 Software (PPC_LINUX_IOSD-UNIVERSALK9_NPE-M), Version 15.4(1)S1, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2014 by Cisco Systems, Inc.
Compiled Sat 01-Mar-14 10:37 by mcpre
Marcelo
Don Jacob
Cisco feature navigator says the device with that IOS does not support netflow.
http://tools.cisco.com/ITDIT/CFN/jsp/SearchBySoftware.jsp
Select your IOS version and you can verify after selecting to filter by feature and typing in netflow.
Don Jacob
http://www.solarwinds.com/netflow-traffic-analyzer.aspx
PS: Dont forget to rate and close helpful answers.
Regards, Don Thomas Jacob http://www.solarwinds.com/netflow-traffic-analyzer.aspx Head Geek @ SolarWinds NOTE: Please rate and close questions if you found any of the answers helpful.
