ASR920 12 SZ M Problem
mrandrewwww
I have done a reset from rommon , but when reloading it appears like this, can this be fixed? how do I do it? please Help
I'm very confused now
bad errorbad error
6 Replies 6
Hello!
Did you try changing the baud speed on the console?
BR
****Kindly rate all useful posts*****
Haven't changed the baudrate yet, the baudrate used is 9600, is it correct?
Yes its correct. Did you try getting into rommon? Press break while booting up? Then try loading an image from USB. Maybe your image is corrupted on the flash.
BR
Yes, I tried to enter Rommon, I pressed brake when booting, how do I load the image from the USB?is there any way to save?
using a baud speed of 9600 it looks like this
solved,i use baudrate 19200
