ASR9901 router MAJ LED and all interface port showing RED light
tim.lim.lim
Hi, I have a new ASR-9901-120G router. I noticed MAJ LED and all interface port is showing RED light.
When inter-connected fiber patch cord to 2 port having GLC-LH-SMD transceiver. The status show up.
May I know is it a normal behaviour that all interface is showing RED light when it is not connected ?
As for MAJ LED showing red light. It show the alarm info when login to the router:
show alarm
Location       Severity       Group                  Description
0/RSP0        major           fpd_infra              IPU-FPGA: Golden FPGA is below minimum version. perform force fpd upgrade
0/RSP0        major           fpd_infra              IPU-FSBL: Golden FPGA is below minimum version. perform force fpd upgrade
0/RSP0        major           fpd_infra              IPU-Linux: Golden FPGA is below minimum version. perform force fpd upgrade
0/0               major           fpd_infra              IPU-FPGA: Golden FPGA is below minimum version. perform force fpd upgrade
0/0              major           fpd_infra              IPU-FSBL: Golden FPGA is below minimum version. perform force fpd upgrade
0/0              major           fpd_infra              IPU-Linux: Golden FPGA is below minimum version. perform force fpd upgrade
May I know what is the issue ? Pls kindly advise how to troubleshoot this.
Thks
tim
5 Replies 5
I think you need to upgrade your FPD. Check the link below for instructions...
https://www.cisco.com/c/en/us/td/docs/routers/crs/software/crs_r3-9/system_management/configuration/mguide/yc39crs1_chapter6.html
Hi Georg & to all who can advise,
Thanks for the advice, there is no more alarm after upgrade FPD. But the Integrated interfaces (16x1 GE, 24x 1/10 GE, 2x100 GE) is still showing red light, may I know is it normal ? Please kindly advise.
Below is the inventory and interface status:
RP/0/RSP0/CPU0:ios#sh inventory
Mon Feb 10 09:48:52.092 UTC
NAME: "0/RSP0", DESCR: "ASR 9901 Route processor"
PID: ASR-9901-RP       , VID: V01, SN: FOC2351P6LR
NAME: "0/0", DESCR: "ASR 9901 Line card"
PID: ASR-9901-LC       , VID: V01, SN: FOC2351PB0F
NAME: "GigabitEthernet0/0/0/0", DESCR: "1000BASE-LX/LH SFP transceiver module, MMF/SMF, 1310nm, DOM"
PID: GLC-LH-SMD        , VID: V01, SN: AVJ22423F7T
NAME: "GigabitEthernet0/0/0/1", DESCR: "1000BASE-LX/LH SFP transceiver module, MMF/SMF, 1310nm, DOM"
PID: GLC-LH-SMD        , VID: V01, SN: AVJ22423E8M
NAME: "GigabitEthernet0/0/0/2", DESCR: "1000BASE-LX/LH SFP transceiver module, MMF/SMF, 1310nm, DOM"
PID: GLC-LH-SMD        , VID: V01, SN: AVJ224237E1
NAME: "GigabitEthernet0/0/0/3", DESCR: "1000BASE-LX/LH SFP transceiver module, MMF/SMF, 1310nm, DOM"
PID: GLC-LH-SMD        , VID: V01, SN: AVJ22423E82
NAME: "GigabitEthernet0/0/0/4", DESCR: "1000BASE-LX/LH SFP transceiver module, MMF/SMF, 1310nm, DOM"
PID: GLC-LH-SMD        , VID: V01, SN: AVJ22423E7L
NAME: "TenGigE0/0/0/8", DESCR: "10GBASE-LR SFP+ Module for SMF"
PID: SFP-10G-LR        , VID: V02, SN: AVD2315K4D3
NAME: "Rack 0", DESCR: "ASR 9901 Chassis"
PID: ASR-9901          , VID: V01, SN: FOC2401NQFQ
NAME: "0/FT0", DESCR: "ASR 9901 Fan Tray"
PID: ASR-9901-FAN      , VID: V01, SN: FOC2401P31E
NAME: "0/FT1", DESCR: "ASR 9901 Fan Tray"
PID: ASR-9901-FAN      , VID: V01, SN: FOC2338NGXJ
NAME: "0/FT2", DESCR: "ASR 9901 Fan Tray"
PID: ASR-9901-FAN      , VID: V01, SN: FOC2401P306
NAME: "0/PT0", DESCR: "Simulated Power Tray IDPROM"
PID: A9K-AC-PEM        , VID: V03, SN: FOT1981P81A
NAME: "0/PT0-PM0", DESCR: "1600W AC Power Module"
PID: A9K-1600W-AC      , VID: V01, SN: POG2345Z82G
NAME: "0/PT0-PM1", DESCR: "1600W AC Power Module"
PID: A9K-1600W-AC      , VID: V01, SN: POG2345Z81C
Below is the interface status.
When fiber cable is connected to Gi0/0/0/2Gi0/0/0/4 , it will show up and LED become green light
RP/0/RSP0/CPU0:ios#sh int brief
               Intf       Intf        LineP              Encap  MTU        BW
               Name       State       State               Type (byte)    (Kbps)
                Nu0          up          up               Null  1500          0
    Mg0/RSP0/CPU0/0  admin-down  admin-down               ARPA  1514      10000
          Gi0/0/0/0        down        down               ARPA  1514    1000000
          Gi0/0/0/1        down        down               ARPA  1514    1000000
          Gi0/0/0/2        up             up               ARPA  1514    1000000
          Gi0/0/0/3        down        down               ARPA  1514    1000000
          Gi0/0/0/4        up            up               ARPA  1514    1000000
          Gi0/0/0/5        down        down               ARPA  1514    1000000
          Gi0/0/0/6        down        down               ARPA  1514    1000000
          Gi0/0/0/7        down        down               ARPA  1514    1000000
         Gi0/0/0/34        down        down               ARPA  1514    1000000
         Gi0/0/0/35        down        down               ARPA  1514    1000000
         Gi0/0/0/36        down        down               ARPA  1514    1000000
         Gi0/0/0/37        down        down               ARPA  1514    1000000
         Gi0/0/0/38        down        down               ARPA  1514    1000000
         Gi0/0/0/39        down        down               ARPA  1514    1000000
         Gi0/0/0/40        down        down               ARPA  1514    1000000
         Gi0/0/0/41        down        down               ARPA  1514    1000000
         Hu0/0/0/20        down        down               ARPA  1514  100000000
         Hu0/0/0/21        down        down               ARPA  1514  100000000
          Te0/0/0/8        down        down               ARPA  1514   10000000
          Te0/0/0/9        down        down               ARPA  1514   10000000
         Te0/0/0/10        down        down               ARPA  1514   10000000
         Te0/0/0/11        down        down               ARPA  1514   10000000
         Te0/0/0/12        down        down               ARPA  1514   10000000
         Te0/0/0/13        down        down               ARPA  1514   10000000
         Te0/0/0/14        down        down               ARPA  1514   10000000
         Te0/0/0/15        down        down               ARPA  1514   10000000
         Te0/0/0/16        down        down               ARPA  1514   10000000
         Te0/0/0/17        down        down               ARPA  1514   10000000
         Te0/0/0/18        down        down               ARPA  1514   10000000
         Te0/0/0/19        down        down               ARPA  1514   10000000
         Te0/0/0/22        down        down               ARPA  1514   10000000
         Te0/0/0/23        down        down               ARPA  1514   10000000
         Te0/0/0/24        down        down               ARPA  1514   10000000
         Te0/0/0/25        down        down               ARPA  1514   10000000
         Te0/0/0/26        down        down               ARPA  1514   10000000
         Te0/0/0/27        down        down               ARPA  1514   10000000
         Te0/0/0/28        down        down               ARPA  1514   10000000
         Te0/0/0/29        down        down               ARPA  1514   10000000
         Te0/0/0/30        down        down               ARPA  1514   10000000
         Te0/0/0/31        down        down               ARPA  1514   10000000
         Te0/0/0/32        down        down               ARPA  1514   10000000
         Te0/0/0/33        down        down               ARPA  1514   10000000
Thks & Rgds
tim
a red LED usually means that the port state is up, but there is no link. What happens to the port status when you connect these ports to something ?
Hi Georg,
When I connect fibre cable to interface G0/0/0/2 and G0/0/0/4, LED is showing GREEN light. And status show UP, when console into the router.
And other Integrated interfaces (16x1 GE, 24x 1/10 GE, 2x100GE) is showing RED light and status DOWN when there is no fibre cable connected.
Am I correct to say, it is normal to show RED light when there is no link connected ?
Hi Georg
the link currently is not working do you have another link
