Asr9k flowspec
Rafi Shemesh
I read Xander document about flowspec, it was very helpful (thanks), but i neeed to ask something
1. I have version 5.1.3, and i saw in the blog that cisco start support asr9k flowspec only in version 5.2 i search it in cisco feature navigate but i didn't find it is it true ?
2.In client server mode the client will be the "server" and the provider will be the client ?
3.Are these settings ok ?
applicable to both client and server, we need to enable the new address family for advertisement
router bgp 100
 address-family ipv4 flowspec
 address-family ipv6 flowspec
neighbor 1.1.1.1
  remote-as 100
  ! Ties it to a neighbor configuration
Server configuration
class-map
class-map type traffic match-all udp53-protect
match destination-address ipv4 2.2.0.0/16
match protocol 17
match destination-port 53
end-class-map
policy-map
policy-map type pbr udp53-protect-pbr
class type traffic udp53-protect
action police rate 1000000000 (1G)
class class-default  (maybe i have to build class-default)
end-policy-map
The following ties the flowspec to the PBR policies defined earlier
flowspec
local-install interface-all
address-family ipv4
service-policy type pbr udp53-protect-pbr
Rafi
Vinit Jain
Hello Rafi
Regarding the 1st question, the support for BGP FlowSpec was introduced in XR 5.2.0 release. So even if you have the cli available in early release, I dont think the configuration might work properly.
Regarding the 2nd question, the Provider edge is the controller. Thus the server.
The below CCO document has the information about both the questions.
http://www.cisco.com/c/en/us/td/docs/routers/crs/software/crs_r5-2/routing/configuration/guide/b_routing_cg52xcrs/b_routing_cg52xcrs_chapter_011.html
I will look into the configuration and let you know if its fine.
Vinit
--Vinit
Hi Vinit,
Thank you for your replay,
I probably missed something, about question 2
I have bgp peer to my isp provider, from what i understand all the class-map, policy-map should be on my router and isp provider need to configure only this
router bgp 100
neighbor 1.1.1.1
  remote-as 100
So my router "tell" to provider router what to do when my router "see" udp 53 traffic
If this is not right can you please explain me again because this what i understand from the pdf.
Rafi
Hi Vinit,
In this link they explain that the server (controller) is on the customer side, they also said that the ISP must trust his costumer so this is the reason that usually the controller on the isp side ?
Lets say that my isp trust me can i (the customer) be the controller ?
http://gurudatt28227.blogspot.co.il/
Regrads
Rafi
