07-29-2016 08:35 AM - edited 03-07-2019 12:18 AM
i have in ASR9K a LC A9K-8T-E. The LC reboot:
LC/0/2/CPU0: pfm_node_lc[295]: %PLATFORM-NP-0-HW_DOUBLE_ECC_ERROR : Set|prm_server_tr[159827]|0x1008004|NP DOUBLE ECC ERROR, NP=4, memId=19, subMemId=0x1
LC/0/2/CPU0:Jul 16 01:30:09 : pfm_node_lc[295]: %PLATFORM-PFM-0-CARD_RESET_REQ : pfm_dev_sm_perform_recovery_action, Card reset requested by: Process ID: 159827 (prm_server_tr), Fault Sev: 0, Target node: 0/2/CPU0, CompId: 0x1f, Device Handle: 0x1008004, CondID: 1001, Fault Reason: NP DOUBLE ECC ERROR, NP=4, memId=19, subMemId=0x1
RP/0/RSP0/CPU0:Jul 16 01:30:09 : shelfmgr[410]: %PLATFORM-SHELFMGR-6-NODE_KERNEL_DUMP_EVENT : Node 0/2/CPU0 indicates it is doing a kernel dump.
Is thies a bug ?
RP/0/RSP0/CPU0:ASR-02#admin show platform | i 0/2/CPU0
Fri Jul 29 17:29:22.278 CEST
0/2/CPU0 A9K-8T-E IOS XR RUN PWR,NSHUT,MON
Cisco IOS XR Software, Version 5.3.1[Default]
RP/0/RSP0/CPU0:ASR-02#admin show diagnostic result loc all | b 0/2/CPU0
Fri Jul 29 17:31:47.319 CEST
A9K-8T-E 0/2/CPU0:
Overall diagnostic result: PASS
Diagnostic level at card bootup: bypass
Test results: (. = Pass, F = Fail, U = Untested)
1 ) PHYCtrlScratchRegister ----------> .
2 ) PortCtrlScratchRegister ---------> .
3 ) CPUCtrlScratchRegister ----------> .
4 ) NPScratchRegister ---------------> .
5 ) BridgeScratchRegister -----------> .
6 ) FIAScratchRegister --------------> .
7 ) EccSbeTest ----------------------> U
8 ) LcEobcHeartbeat -----------------> .
9 ) NPULoopback ---------------------> .
10 ) NPULoopbackUseRxPath ------------> .
11 ) FPDimageVerify ------------------> U
Can i help you?
Regrads
Frank
12-09-2019 09:29 PM
12-09-2019 10:58 PM
- This is a hardware problem on the Network Processing Card; you should have it replaced.
M.
12-09-2019 11:34 PM
