Bookmark
Subscribe
1463
Router USB dongle Support
Network Digger
Hi there, how to know if a cisco router can use a USB dongle for internet connection, I didn’t find it written clearly in the data sheet.
THX
5 Replies 5
Seb Rupik
Hi there,
I think nearly all USB devices which provide internet connectivity require drivers specific to the OS they are connected to. Combine this with the fact you cannot load modules/ drivers to an IOS/ IOS-XE/ etc device means this is not a supportable option.
Nice idea though! :)
cheers,
Seb.
which router model do you have ?
Leo Laohoo
Not possible and not supported.
actually, think a lot of the RV routers do support dongles, such as the ones below. You need to search for the model and use they keywords 'USB Compatibility Matrix'.
https://www.cisco.com/c/dam/en/us/td/docs/routers/csbr/RV340/USB_compatibility_matrix/Rv340_compatibility_matrix.pdf
Learn something new everyday, thanks @Georg Pauwen
