Assign multi IP address at the same interface at router
machiasiaweb
Is it possible to assign multi IP address to the same interface at router and what should be command.  As I only find some configuration example which is configure 2 ip address for the same interface.
Thx!
3 Accepted Solutions
mrdogantr
for example;
interface GigabitEthernet0/0
ip address 10.10.10.10 255.255.255.0
ip address 20.20.20.20 255.255.255.0 secondary
hth
Muammer
You can configure only one primary address and as many secondary addresses as you want up to hw/sw platform limit.
Regards.
Hi Machi that's correct. you can use multiple secondary ip.
5 Replies 5
mrdogantr
for example;
hth
Muammer
Regards.
Yes, I found this example also.  Is that means
ip address 30.30.30.30 255.255.255.0 secondary
Is it Correct?
Thank you!!
