Assigning Privilege Levels
hclisschennai
Hi Everybody,
I am trying to assign privilege level 6 to my support staff, so that he can see the following output
1. config t
2. interface ser 0/0
privilege configure level 6 interface
privilege exec level 6 configure terminal
But, the support user is able to see other few commands also which i donot want him to do. The other commands visible to him is below
call
default
dss
end
exit
help
interface
no
defaults
oer
I want to remove this commands from display for this user. I tried "no privilege". But it is not working.
How to achieve this. Please help
RBK
Edison Ortiz
RBK,
Those commands default to priv level 0 (with the exception of interface since you've added to priv level 6).
To move them away from priv level 0, you need to assign them to priv level 7 - this way priv level 6 won't be able to see them.
HTH,
__
Edison.
Edison Ortiz
RBK,
HTH,
__
Edison.
