07-24-2019 05:40 AM
I'm rusty with QoS. Really haven't had to work with it much since a lot of the networks I work on have bandwidth to spare. I've been working with some MPLS sites that have lower bandwidth connections, around 10Mbps is typical for these sites.
There have been issues and I believe it is due to the service provider dropping packets due to the CIR being exceeded. I'm trying to understand the QoS configuration better. The goal is to make some adjustments to allow file transfer over SMB to function better (TCP 445). I am looking for some help in how to best implement this as well as understand what is already occurring. The remote site was setup with AutoQoS but I don't think it is taking into account the slower upstream bandwidth. I have the service provider's config as well which is using IPP (precedence) to do it's shaping.
Would be super helpful if someone who is more knowledgable could walk me through how the current config is working and where best to adjust to help alleviate issues.
Here is the switch where all clients are connecting:
class-map match-any AutoQos-4.0-Output-Multimedia-Conf-Queue match dscp af41 af42 af43 match cos 4 class-map match-any AutoQos-4.0-Output-Bulk-Data-Queue match dscp af11 af12 af13 match cos 1 class-map match-any AutoQos-4.0-Output-Priority-Queue match dscp cs4 cs5 ef match cos 5 class-map match-any AutoQos-4.0-Output-Multimedia-Strm-Queue match dscp af31 af32 af33 class-map match-any AutoQos-4.0-Voip-Data-CiscoPhone-Class match cos 5 class-map match-any AutoQos-4.0-Voip-Signal-CiscoPhone-Class match cos 3 class-map match-any non-client-nrt-class class-map match-any AutoQos-4.0-Default-Class match access-group name AutoQos-4.0-Acl-Default class-map match-any AutoQos-4.0-Output-Trans-Data-Queue match dscp af21 af22 af23 match cos 2 class-map match-any AutoQos-4.0-Output-Scavenger-Queue match dscp cs1 class-map match-any AutoQos-4.0-Output-Control-Mgmt-Queue match dscp cs2 cs3 cs6 cs7 match cos 3 ! policy-map port_child_policy class non-client-nrt-class bandwidth remaining ratio 10 policy-map AutoQos-4.0-Output-Policy class AutoQos-4.0-Output-Priority-Queue priority level 1 percent 30 class AutoQos-4.0-Output-Control-Mgmt-Queue bandwidth remaining percent 10 queue-limit dscp cs2 percent 80 queue-limit dscp cs3 percent 90 queue-limit dscp cs6 percent 100 queue-limit dscp cs7 percent 100 queue-buffers ratio 10 class AutoQos-4.0-Output-Multimedia-Conf-Queue bandwidth remaining percent 10 queue-buffers ratio 10 class AutoQos-4.0-Output-Trans-Data-Queue bandwidth remaining percent 10 queue-buffers ratio 10 class AutoQos-4.0-Output-Bulk-Data-Queue bandwidth remaining percent 4 queue-buffers ratio 10 class AutoQos-4.0-Output-Scavenger-Queue bandwidth remaining percent 1 queue-buffers ratio 10 class AutoQos-4.0-Output-Multimedia-Strm-Queue bandwidth remaining percent 10 queue-buffers ratio 10 class class-default bandwidth remaining percent 25 queue-buffers ratio 25 policy-map AutoQos-4.0-Trust-Dscp-Input-Policy class class-default set dscp dscp table AutoQos-4.0-Trust-Dscp-Table policy-map AutoQos-4.0-CiscoPhone-Input-Policy class AutoQos-4.0-Voip-Data-CiscoPhone-Class set dscp ef police cir 128000 bc 8000 conform-action transmit exceed-action set-dscp-transmit dscp table policed-dscp class AutoQos-4.0-Voip-Signal-CiscoPhone-Class set dscp cs3 police cir 32000 bc 8000 conform-action transmit exceed-action set-dscp-transmit dscp table policed-dscp class AutoQos-4.0-Default-Class set dscp default
This is the service policy on the interface facing the MPLS circuit:
service-policy input AutoQos-4.0-Trust-Dscp-Input-Policy service-policy output AutoQos-4.0-Output-Policy
On the service provider's router, here's what's configured there:
class-map match-any best-effort match ip precedence 0 1 class-map match-any network-control match ip precedence 4 6 7 class-map match-any expedited-forwarding match ip precedence 5 class-map match-any assured-forwarding match ip precedence 2 3 ! policy-map Template-8 class expedited-forwarding police cir percent 20 conform-action transmit exceed-action drop priority percent 20 class network-control bandwidth percent 10 random-detect class best-effort bandwidth percent 69 random-detect policy-map QOS class class-default shape average 10000000 service-policy Template-8 policy-map rate-limit-20M-out class class-default shape average 20000000
And finally, on the SP's router facing into their network:
service-policy output QOS
Solved! Go to Solution.
07-29-2019 09:12 AM
07-24-2019 09:25 AM - edited 07-24-2019 09:27 AM
What is your device and its running IOS version?
Is your WAN topology p2p or multi-point?
What's the WAN's physical hand-off bandwidth?
Generally speaking, you too would want to shape for your available bandwidth, and then prioritize as desired. (For most traffic, a class-default using FQ [if supported on you platform - if not, it can be struggle] works very well. From that you can add classes for SLA traffic, like VoIP, if needed. [NB: personally I'm not a fan of auto-QoS, and random-detect is best avoided unless you're a real QoS guru.)
Regarding the current QoS config, yours appears to be based on Cisco's v4 autoQoS, which can probably be better explained reading Cisco documentation. I don't know how well Cisco's QoS model matches your SLA needs, so cannot comment on whether it's of benefit to you or not.
Your SP's QoS appears to have a policy shaper for both 10 and 20 Mbps. The former using a subordinate policy to treat 3 class of traffic differently. BTW, their mappings for IPPrec don't really agree with RFCs. For example, the AF classes should have an IPPrec of 1..4.
As long as you shape your egress, to your SP not to exceed their CIR, their QoS should matter little except perhaps if yours is a multipoint topology that has congestion from the SP to you.
07-25-2019 07:11 AM
Thanks for your reply,
Hand off is Ethernet to the SP's router, then Ethernet to local switch. Topology is multi-point mesh. Physical hand off bandwidth is 100Mbps.
I believe the best way to approach this is to:
1. Shape traffic egress toward the MPLS router to 10Mbps
2. Utilize IPP to tag traffic that the MPLS router will then apply its QoS rules to
I'm thinking the best way is to simplify this by getting rid of AutoQoS entirely and setup some kind of map of DSCP markings to precedence that the MPLS router will watch for.
Still learning here... so what is the best method to incorporate a shaped overall interface but also map DSCP to IPP. I'm sure I'll figure it out once I get through some more documentation but I like to see what people do with experience, often times its more logical than what is outlined in Cisco docs.
07-25-2019 10:25 AM - edited 07-25-2019 10:26 AM
Yea, you'll want to limit your output bandwidth to whatever you've obtained from your provider. When it's an actual physical Ethernet bandwidth, you sometimes have the option to run your interface at that bandwidth. The advantage of that, QoS works better with a physical bandwidth than with a shaper.
I believe some Cisco shapers don't account for L2 overhead. If yours does not, you can shape slower to make an allowance. I've found about 15% (slower) often accounts for about the average L2 overhead.
If you device supports fair-queue, that well handles about 90% of QoS needs. (I wonder if the RFC and Cisco 10+ class models are due to not always being able to have FQ.)
My general purpose QoS model is:
policy-map Sample
class realtime
priority percent 30
class foreground
bandwidth remaining percent 81
fair-queue
class background
fair-queue
class class-default
bandwidth remaining percent 9
fair-queue
For the above, most traffic should go into class class-default. The background class can be used for scavenger type traffic or low-priority bulk traffic. The foreground class can be used for light weight SLA critical traffic. The realtime class would be used for traffic like VoIP bearer.
Having QoS for your egress to your provider's "cloud" deals with possible congestion to it.
For possible egress congestion from provider's "cloud" to your locations, you need to depend on the provider's QoS model that comes closest to your needs. Generally, you use ToS markings to "signal" to the provider how your traffic should be mapped into their QoS.
BTW, your egress QoS treatment, except for ToS markings, doesn't need to align with your provider's QoS model.
IPPrec is the same 1st 3 bits of the ToS, as also used by DSCP. This was intentional with the original DSCP RFC so as to overlap with the prior IPPrec RFC to possibly maintain somewhat similar treatment regardless whether the router is using IPPrec or DSCP prioritization. The one major later exception, the RFC for scavenger marking (CS1) is a low priority than BE, but with IPPrec, the corresponding IPPrec 1 is of a higher priority than IPPrec 0.
07-26-2019 05:40 AM
Okay, that makes sense. And working through this is very helpful.
How does the bandwidth command come into play if it were to be configured on the interface facing the MPLS router? Would that then inform the correct values for the percentages?
So, on the actual marking of traffic. I'll need to mark traffic as it enters the host interfaces or trust the marking already applied. I do want voice to be prioritized and I suspect that will already be marked leaving the device. But we will also need to classify SMB traffic to a specific subnet. I would need a policy on all host facing interfaces in the inbound direction, correct? How does this look?:
class-map SMB-TRAFFIC match-any
match access-group 100
policy-map ENT-PM-INPUT
class SMB-TRAFFIC
set
What I am still a bit fuzzy on is where the shaping would come into play and bringing it all together. Does this look correct?
Goal is to prioritize voice traffic from Cisco phones, then SMB traffic to servers across the MPLS. The rest is best-effort. Do I also need to then ma
access-list 100 permit tcp any 10.20.20.0 0.0.0.255 eq 445
class-map VOICE-DATA match-any
match cos 5
match ip dscp ef
class-map VOICE-SIGNAL match-any
match cos 3
class SMB-TRAFFIC
set dscp cs3
set dscp cs5
set dscp cs7
policy-map ENT-PM-OUTPUT
class VOICE-DATA
priority percent 30
class SMB-TRAFFIC
fair-queue
class VOICE-SIGNAL
fair-queue
class background
fair-queue
class class-default
fair-queue
The service provider is using IPP for the MPLS network, so my idea is that I'm matching that internally. From what I gather, the cs5 would match IP Precedence 5 etc.
I would apply the INBOUND policies to host and phone facing ports and the OUTBOUND policy toward the MPLS router. Question is where do I do the interface shaping? Do I have to nest a policy?
Lastly, for the phones I would have to set the interfaces to trust the existing markings, correct?
Thanks!
07-26-2019 12:20 PM
07-28-2019 02:23 PM
This is great, I'm building a baseline for further learning!
Here's what I've put together, let me know if you see flaws in the logic please.
I want to have phones take the expected priority. On the host facing interfaces I have an input service policy that looks for the CS5 tags which is expected from a phone voice stream, and then assigns an EF tag. It also looks for the signaling traffic that has a CS3 tag which is expected from voice call setup and assigns the AF31. AF31 = IPP 3 and EF = IPP 5.
I am also looking for traffic that is going to a critical server for SMB traffic. You said that this should probably go to the class-default but I'd like to test performance with it in place. It may actually hinder everything.
I then have an output policy facing the SP that shapes the traffic to 10Mbps and has a child policy that does the prioritization.
Let me know if this seems like a good way of doing things and where I could improve.
Also, a few questions:
- Does the interface "bandwidth" command need to be stated in order for the percentages to function correctly?
- AutoQOS utilized an input and an output service-policy on all interfaces. Is this to priortize data at each interface instead? Should I do the same?
- I put a table-map in place since it is what I saw in AutoQoS. I'm using that as a reference tool, maybe not needed?
- And lastly, should I be using "trust" commands to trust existing markings or is what I have sufficient?
Really appreciate the assistance with this, it is truly clearing things up and I'm sure this thread will be helpful for others.
Best
07-29-2019 09:12 AM
07-29-2019 06:13 PM
07-30-2019 02:04 PM
Another question:
This is a 3850 platform - no fair-queue option exists. I've implemented the config but have to wait for users to get in to see if things are working. Can you peek at this to see if it doesn't have any major errors? Anything else I can add to ensure queueing is occurring correctly? I really want to make sure traffic is shaped an not just dropped. The client's complaint is mainly with file shares (SMB) and Internet traffic. But there is only so much that can be done.
class-map match-any realtime match ip dscp ef class-map match-any foreground match ip dscp af31 class-map match-any background match ip dscp af11 af12 af13 class-map Cisco-VOIP-Data match cos 5 class-map Cisco-VOIP-Signal match cos 3 policy-map ENT-INPUT-PMAP class Cisco-VOIP-Data set ip dscp ef police cir 128000 bc 8000 conform-action transmit class Cisco-VOIP-Signal set ip dscp af31 police cir 32000 bc 8000 conform-action transmit policy-map ENT-OUTPUT-PMAP class class-default shape average 10000000 service-policy ENT-OUTPUT-TEMPLATE policy-map ENT-OUTPUT-TEMPLATE class realtime priority percent 30 class foreground bandwidth remaining percent 81 class background bandwidth remaining percent 1 class class-default bandwidth remaining percent 9
07-30-2019 04:25 PM - edited 07-30-2019 04:27 PM
That's looks like a fairly good first policy to try. You might try changing your background class to match just CS1.
You should also decide what to do with overrate VoIP traffic. Choices include dropping or marking down. What you have won't do anything to your overrate traffic beyond providing stats that it's happening.
Since you don't have the FQ feature, be prepared to create additional classes for your BE traffic.
You might add to you ingress policy a policer that will mark non-VoIP, high bandwidth usage, with a marking to separate it from other BE traffic.
on
Again, without FQ, you may find you need to adjust you egress policy quite a bit. In the meantime, even if it doesn't immediately improve the user experience, with your shaper and classes, you should have some better stats on congestion.
07-31-2019 05:39 AM
Okay, I'll have to look into adjustments then. What would you recommend doing to traffic that has exceeded the input policing? Markdown to af31 or similar?
Since I have this running, I'm thinking I could use some help interpreting the results. Can you tell me what you see here? I am seeing 'packet' and expecting that this is the number of packets that have been matched by the class within the policy.. but I'm not seeing what I'd expect. I'm seeing some that have packets matched but zero 'conformed' and some that have values for both. Trying to understand that discrepancy.
Also, for my output policy that is doing the shaping, I'm seeing zero for just about everything except total drops. What do you think?
Here is an example interface with inputs:
GigabitEthernet1/0/10
Service-policy input: ENT-INPUT-PMAP
Class-map: Cisco-VOIP-Data (match-any)
312994 packets
Match: cos 5
0 packets, 0 bytes
5 minute rate 0 bps
QoS Set
ip dscp ef
police:
cir 128000 bps, bc 8000 bytes
conformed 0 bytes; actions:
transmit
exceeded 0 bytes; actions:
drop
conformed 0000 bps, exceeded 0000 bps
Class-map: Cisco-VOIP-Signal (match-any)
193191 packets
Match: cos 3
0 packets, 0 bytes
5 minute rate 0 bps
QoS Set
ip dscp af31
police:
cir 32000 bps, bc 8000 bytes
conformed 1282434 bytes; actions:
transmit
drop
Class-map: SMB-TRAFFIC (match-any)
17869 packets
Match: access-group name SMB-MPLS
0 packets, 0 bytes
5 minute rate 0 bps
QoS Set
ip dscp af31
Class-map: class-default (match-any)
3669649 packets
Match: anyAnd here is the output toward the SP router, again not seeing anything happening here.
GigabitEthernet2/0/1
Service-policy output: ENT-OUTPUT-PMAP
0 packets
Match: any
Queueing
(total drops) 2079529
(bytes output) 768317836
shape (average) cir 10000000, bc 40000, be 40000
target shape rate 10000000
Service-policy : ENT-OUTPUT-TEMPLATE
queue stats for all priority classes:
Queueing
(total drops) 0
(bytes output) 19482271
Class-map: realtime (match-any)
0 packets
Match: ip dscp ef (46)
0 packets, 0 bytes
5 minute rate 0 bps
Priority: 30% (3000 kbps), burst bytes 75000,
Class-map: foreground (match-any)
0 packets
Match: ip dscp af31 (26)
0 packets, 0 bytes
5 minute rate 0 bps
Queueing
(total drops) 1518
(bytes output) 37137977
bandwidth remaining 81%
Class-map: background (match-any)
0 packets
Match: ip dscp cs1 (8)
0 packets, 0 bytes
5 minute rate 0 bps
Queueing
(total drops) 0
(bytes output) 78
bandwidth remaining 1%
0 packets
Match: any
Queueing
(total drops) 2078011
(bytes output) 711697510
bandwidth remaining 9%
07-31-2019 09:19 AM
