Asynchronous Interfaces
mwandu
Hi Guys,
Please help with the following situation I am facing. I am implementing dial-up back up solution for DSL link. When the DSL link is down, the backup line comes up, meaning line protocol is up and traffic up to the router.
The issue is the dynamic routing does not work, all the routes are lost as soon as the backup line comes up. EIGRP is the routing protocol running on the router.
What is your thought guys? Thanks in advance.
5 Replies 5
devang_etcom
Level 7
Level 7
can you show me your configuration...?
how you configure backup... and what you have publish in routing protocol?
regards
Devang
Could this statement be the source of my problem since I using EIGRP. I found this on the Cisco website in a article on Configuring Asynchronous Interfaces and Lines.
"The async dynamic routing command routes IP packets on an asynchronous interface, which permits
you to enable the Interior Gateway Routing Protocol (IGRP), Routing Information Protocol (RIP), and
Open Shortest Path First (OSPF) routing protocols for use when the user makes a connection using the
ppp or slip EXEC commands. The user must, however, specify the /routing keyword at the SLIP or PPP
command line."
I will appreciate feeback on this.
Following is the configuration;
Branch office Router
_ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _
interface FastEthernet0
description --------------------> NE LAN
ip address 192.9.x.x.255.255.0
speed auto
full-duplex
interface Serial0
description NE <--------------> Head Office
bandwidth 64
ip unnumbered FastEthernet0
ip directed-broadcast
encapsulation ppp
backup delay 180 180
backup interface Async2
compress stac
interface Async2
bandwidth 64
encapsulation ppp
dialer in-band
dialer enable-timeout 10
dialer string 226301
dialer redial interval 30 attempts 10 re-enable 300
dialer-group 1
async mode interactive
compress stac
ppp chap hostname xxnort
ppp chap password xxx
router eigrp 145
network 192.9.20.0
network 192.9.200.0
no auto-summary
ip classless
ip route 0.0.0.0 0.0.0.0 Serial0
no ip http server
dialer-list 1 protocol ip permit
HQ Office Router part of the configuration
interface Group-Async1
bandwidth 56
ip unnumbered FastEthernet0/0
encapsulation ppp
ip tcp header-compression
dialer in-band
dialer idle-timeout 600
dialer-group 1
no peer default ip address
ppp authentication chap
ppp ipcp mask 255.255.255.0
ppp ipcp route default
group-range 34 48
routing dynamic
router eigrp 145
network 192.9.200.0
no auto-summary
router eigrp 100
network 192.9.198.0
auto-summary
ip local pool DIALIN 192.9.200.218 192.9.200.225
ip classless
ip route 192.168.2.0 255.255.255.0 192.212.200.1
I hope this help with troubleshooting.
Since you are using IP unnumbered and have not included all the interfaces in your post its hard to say exactly what the issues is. Without all the addresses its hard to say if EIGRP will even form neighbors.
Verify that show EIGRP neighbor has a neighbor both when running on the serial line and on the backup.
Unless EIGRP is injecting a default route you will lose your default route when the serial line goes down since you route to the serial line. If you want to continute to use static put a second default static route in with a higher metric pointing to the dialup. This will allow you to still have a default route when the serial line is down.
Ip unnumbered tends to be a lot harder to troubleshoot. If your lan connection goes down you really won't know what the problem is since it will appear the WAN connection went down. Unless there is a reason not to I would eventually change this to use private addresses for your point to point. It makes configuration so much easier and you can just not advertise the private addresses if it will cause routing issues elsewhere in the network.
Since there is no issue with the Back-up interface config, we can safely shift our investigation to analyse whats wrong with the EIGRP Routing.
May I request you to paste the debug IP EIGRP events
whenever the Backup interface has kicked in.
Kindly rate if it helps.
Kind Regards,
Wilson Samuel
