A qustion about PBR
yan.yong
I have two routers,connecing with a link.router A sent traffic to router B,Router B have three ports.I configure pbr and acl on router B,the port B/1 recevie trffice from A, if the traffic match the acl 'TSAP_USERS',the pbr on the port B/1 will set this taffic to the port B/2,but in the B'route table ,this traffic next hop is port B/3, I configure acl 'not_TSAP_USERS' to deny this traffic on port B/3,
however the traffic defining in acl 'TSAP_USERS',flow to port B/2 because of pbr,and in spite of the acl 'not_TSAP_USERS' ,pass through port B/3 .
I find the pbr changed this packte's destination output interface. so the acl'not_TSAP_USERS' on port B/3 don't deny this flow. if I remove the ip poliy route-map from port B/1 ,then acl'not_TSAP_USERS' deny the flow on port B/3.
I want to know whether the activity is right?
thank you ..
Using on pbr
ip access-list extended TSAP_USERS
permit icmp 172.17.2.96 0.0.0.15 host 172.18.2.98 echo
remark Identify traffic for route-map TSAP_TELNET
Using on port B/3
ip access-list extended not_TSAP_USERS
deny icmp 172.17.2.96 0.0.0.15 host 172.18.2.98 echo
permit ip any any
route-map TSAP_TELNET permit 10
match ip address TSAP_USERS
set interface B/2
debug ip packet
*Mar 1 00:07:09.475: IP: s=172.17.2.98 (FastEthernet0/0), d=172.18.2.98 (Serial0/0), len 100, access denied
*Mar 1 00:07:09.475: ICMP type=8, code=0
Mar 1 00:09:45.211: IP: s=172.17.2.98 (FastEthernet0/0), d=172.18.2.98 (Serial0/1.201), g=172.18.2.98, len 100, forward
*Mar 1 00:09:45.211: ICMP type=8, code=0
12 Replies 12
jackyoung
Level 6
Level 6
Can you please provide the configuration file ?
....R B (B/1)----------R A
B/3 /. .\ B/2
RC. .. RD
this's router B configuration:
interface Loopback0
description Dummy LAN segment 1
ip address 172.17.2.5 255.255.255.248
interface Loopback1
description Dummy LAN segment 2
ip address 172.17.2.9 255.255.255.252
interface FastEthernet0/0 (B/1)
description Link TSAP networks
ip address 172.17.2.97 255.255.255.240
ip policy route-map TSAP_TELNET
duplex auto
speed auto
interface Serial0/0
description Normal routed traffic primary link to Dallas
bandwidth 2000
ip address 192.168.1.17 255.255.255.248
ip access-group not_TSAP_USERS out
encapsulation frame-relay
no fair-queue
frame-relay map ip 192.168.1.18 100 broadcast
no frame-relay inverse-arp
frame-relay lmi-type ansi
frame-relay intf-type dce
interface Serial0/1
description Frame relay link to Atlanta
no ip address
interface Serial0/1.201 point-to-point (B/2)
bandwidth 1000
ip address 192.168.1.41 255.255.255.248
ip access-group TSAP_USERS out
frame-relay interface-dlci 201
router eigrp 100
redistribute connected
redistribute static
network 172.17.0.0
network 192.168.1.16 0.0.0.7
no auto-summary
no eigrp log-neighbor-changes
ip classless
ip route 172.17.2.144 255.255.255.240 172.17.2.98
ip http server
permit tcp 172.17.2.96 0.0.0.15 host 172.18.2.98 eq telnet
deny tcp 172.17.2.96 0.0.0.15 host 172.18.2.98 eq telnet
permit ip any any
description Policy route-map for TSAP users to Orlando
set interface Serial0/1.201 Null0
line con 0
exec-timeout 180 0
privilege level 15
line aux 0
thank you
Thanks for the info. According to the config., I can't find the problem. And if the packet is PBR to the B/2, it will not flow to B/3, so B/3 will not deny it. Doesn't it make sense ?
Could you advise your concern ? It is not a local-sharing link that the traffic will only route via one path, once the PBR is working, the traffic will follow the PBR to route and not use the routing table.
Hope this clarify. Please correct me if I overlook something.
thank you for your help
#sh ip rou ei
172.18.0.0/16 is variably subnetted, 8 subnets, 3 masks
D 172.18.2.224/29 [90/2432000] via 192.168.1.18, 00:01:51, Serial0/0
D 172.18.2.208/28 [90/2306560] via 192.168.1.18, 00:01:51, Serial0/0
D 172.18.2.44/30 [90/2432000] via 192.168.1.18, 00:01:51, Serial0/0
D 172.18.2.40/30 [90/2432000] via 192.168.1.18, 00:01:51, Serial0/0
D 172.18.2.8/29 [90/1920000] via 192.168.1.18, 00:01:53, Serial0/0
D 172.18.2.4/30 [90/1920000] via 192.168.1.18, 00:01:53, Serial0/0
D 172.18.2.112/28 [90/1920000] via 192.168.1.18, 00:01:53, Serial0/0
D 172.18.2.96/30 [90/1794560] via 192.168.1.18, 00:01:53, Serial0/0
D 197.197.5.0/24 [90/2304000] via 192.168.1.18, 00:01:53, Serial0/0
In the router B route table, go to the network 172.18.2.98 ,router B direct to next add 192.168.1.18(router C),however the PBR send traffic (destination is 172.18.1.98) to router B port B/2. if using the PBR these traffic will pass B/3 , it seems that the acl don't deny these traffic, why not acl work? if no PBR , acl deny the traffic.I'm perplexed.
I found the PBR changed the origintal packte's destination output interface from d=172.18.2.98 (Serial0/0) to d=172.18.2.98 (Serial0/1.201); it maybe not match the acl 'not_TSAP_USERS' on port B/3,so taffic passed, Does the access control entry include output interface inform ?
I think the router treats PBR traffic like local traffic. Local traffic from the router are not affected by access-list configuration on the interface.
You could also try to enable Fast switching PBR and see if it makes a difference. ip route-cache policy on the interface
i opened the ip route-cache policy on int f0/0 but no any affected.
i tried to modify the pbr from set interface s0/1.201 to set int s0/1 or set int f0/1 , the telnet and echo-reply traffic all are droped by s0/1 and f0/1 ,not redirected to s0/0.
Please check the ACL counter to determine the traffic match ACL or not.
Sorry, I am confused. Can you advise is the PBR working ? If it is working the ACL traffic should not pass through B/3, because it forwarded to B/2. If the router forward the ACL traffic to B/3, it means the PBR not working, i.e. ACL not matched.
Please clarify.
sorry maybe i did't describe expressly.
if I configure the pbr on port f0/0,then traffic is sent to port s0/1.201 by pbr and redirected to port s0/0 by route table ,router forward the traffic .
if i don't configure pbr on f0/0, traffic is sent to s0/0 ,router deny the traffic according to the acl on s0/0.
If the PBR is working, it should redirect the traffic to s0/1.201 and forward to the remote end. Why it redirected to s0/0 ? Could you please provide the trace route result.
Moreover, why you add null0 in the route-map for PBR ?
when i modified the pbr set interface s0/1.201 to set ip next 192.168.1.41 ,using debug ip policy ,i observed there is some
different :
1 using set inter s0/0.201
*Mar 1 00:57:06.887: IP: s=172.17.2.98 (FastEthernet0/0), d=172.18.2.98, len 100, policy match
*Mar 1 00:57:06.891: IP: route map test, item 10, permit
*Mar 1 00:57:06.891: IP: s=172.17.2.98 (FastEthernet0/0), d=172.18.2.98 (Serial0/1.201), len 100, policy routed
*Mar 1 00:57:06.891: IP: FastEthernet0/0 to Serial0/1.201 172.18.2.98
2 using set ip next 192.168.1.41
Mar 1 00:53:36.215: IP: s=172.17.2.98 (FastEthernet0/0), d=172.18.2.98, len 100, policy match
*Mar 1 00:53:36.215: IP: route map test, item 10, permit
*Mar 1 00:53:36.215: IP: s=172.17.2.98 (FastEthernet0/0), d=172.18.2.98 (Serial0/1.201), len 100, policy routed
*Mar 1 00:53:36.215: IP: FastEthernet0/0 to Serial0/1.201 192.168.1.41
the condition 1 router used the route table send packet to port s0/0
the condition 2 router sent packet to port s0/1.201 and drop them
the other question is that why the acl not_TSAP_USERS not deny telnet and echo-rely packets
thank you for help
The ip next-hop should set to the remote IP and not the local interface IP. Please try again.
Please check the ACL counter for not_TSAP_USRES to determine it matched w/ the ACL or not. If there is no increament of the counter then the ACL may be incorrect.Double check the source & destination IP address.
But I still think, once the PBR is working, the traffic of TSAP_USERS will be redirected to s 0/1.201 then there should be such traffic go through s0/0, so the ACL of not_TSAP_USRES should not increase. And the user of FE 0/0 should not access the server via S0/0. Do you mean if the PBR is not work, e.g. S0/1.201 down, then the user will access the server via S0/0 and you have to block it ?
If yes, did you try to disable the PBR and test the access and function of ACL in S0/0 ?
