atm header compression
pokey
Hi all
I'm wondering if header compression is inherited by the subinterfaces for an atm interface as the command of ip tcp header-compression is not availible for the atm subinterface like that of a serial or frame relay interface.
How can i configure this?
paolo bevilacqua
There is no standard for header compression over ATM (aal5snap encapsulation), so I guess this is the reason it is not implemented.
However, if you was to run PPP over the ATM, I think you could use most of the header compression choices:
http://www.cisco.com/en/US/products/ps6350/products_command_reference_chapter09186a00804367d4.html#wp1148046
I was able to configuring header compression on the parent interface, would this be inherited by the subinterface?
I don't think so, most likely the command is accepted because of a bug.
