ATM Interfaces and Router Spec
nathan.deane
This is probably a very simple question but it has been puzzling me today.
I am working with a client who is deploying an MPLS network within the UK with some of the tails being 2 mbps ATM (BT Cellstream). The offer the option to have this presented as either BNC or 120 ohm RJ45.
If the RJ45 connection is chosen then what router and model would be required to handle the ATm AAL encapsulation?
we are looking at 2811's as a standard for the other sites so is it possible to plug the ATM connection directly into teh RJ45 slot on the back and include the AIM-ATM to provide the ATM encaps for the ethernet interface?
Yes, you can configure a pri-group on the 2nd port of the VWIC.
5 Replies 5
tdrais
Level 7
Level 7
It only looks like a ethernet connection it is totally different.
This is still a e1 at the physical level and you need a corresponding interface.
They changed this when the 2800 came out. Used to use a IMA network module but it is no longer supported.
I am told the new method is to use the AIM card you mention along with a wic card. I think you have to use vwic-1mft-e1.
You MPLS vendor can tell you exactly since I assume they put in managed cisco routers all the time.
Hi, thanks for the reponse
It seems like quite an expensive solution for what is just a funky E1..
i have found teh bundle that contains this
E1 ATM bundle incl 1 VWIC2-1MFT-T1/E1 and 1 AIM-ATM. = $2000
I need to also use this router as an SRST device so need a PRI interface...so would it be possible to change out the
VWIC2-1MFT-E1
for
VWIC2-2MFT-E1
and use 1 port for PRI and 1 port for the ATM connection ???
Thanks again
Thanks for the confirmation, i thought it would be a possibility
Afternoon,
I have just one final question with regards to this topic.
Do i have to use a AIM-ATM ? or can I just use the vwic2-2mft-e1 and have the ATM encapsulation done in software ?
