A Cisco 876w Router should work as VPN-Server and Gateway. Everything is set up well, but the Router cannot sync the ATM-Port with the ISP`(german telecom). Two different ports are tryed out, two times with the same result -> no sync. Arcor as my private ISP has no problems to sync the device, why doesn't it work at the telecom-port ? Could there be different default values or protocols ?
May you have some ideas ?
