09-15-2005 02:37 AM - edited 03-03-2019 10:31 AM
Were having problems with a cisco 2600. It has two full T1 lines connected to the two serial ports and it seems to be creating a loop.
The situation is the following:
If we leave serial 0 up and shut down serial 1, speed is 1.5Mbps
If we leave serial 1 up and shut down serial 0, speed is 1.5Mbps
If we leave both serial 0 and serial 1 up, speed is about 0.3Mbps
here, is the running-config:
vrz-gw>ena
Password:
vrz-gw#show runn
Building configuration...
Current configuration : 2402 bytes
version 12.2
service timestamps debug uptime
service timestamps log uptime
hostname vrz-gw
aaa new-model
enable secret 5 xxxxxxxxxxxxxxxxxxxxx.
enable password xxxxxxxxx
username xxxx password 0 xxxxxxxx
ip subnet-zero
no ip source-route
ip cef
ip name-server 141.45.32.xxx
ip dhcp excluded-address 10.0.xxx.0 10.100.255.255
ip dhcp excluded-address 10.xxx.0.0 10.255.255.255
ip dhcp pool 540-main
network 10.0.xxx.0 255.0.0.0
dns-server 141.45.xxx.xxx
default-router 10.254.xxx.xxx
ip inspect name ethernetin cuseeme timeout 3600
ip inspect name ethernetin ftp timeout 3600
ip inspect name ethernetin h323 timeout 3600
ip inspect name ethernetin http timeout 3600
ip inspect name ethernetin rcmd timeout 3600
ip inspect name ethernetin realaudio timeout 3600
ip inspect name ethernetin smtp timeout 3600
ip inspect name ethernetin sqlnet timeout 3600
ip inspect name ethernetin streamworks timeout 3600
ip inspect name ethernetin tcp timeout 3600
ip inspect name ethernetin tftp timeout 30
ip inspect name ethernetin udp timeout 15
ip inspect name ethernetin vdolive timeout 3600
ip audit notify log
ip audit po max-events 100
interface FastEthernet0/0
ip address 141.155.xxx.xxx 255.255.255.248
ip nat outside
shutdown
duplex auto
speed auto
interface Serial0/0
description Point-to-Point xxxxxx - 53.HCGL.xxxxxx
bandwidth 1544
ip address 141.155.xxx.xxx 255.255.255.252
ip nat outside
ip load-sharing per-packet
interface FastEthernet0/1
ip address 10.254.xxx.xxx 255.0.0.0
ip access-group 101 in
ip nat inside
ip inspect ethernetin in
duplex auto
speed auto
interface Serial0/1
description Point-to-Point xxxxxxx - 53.HCGL.xxxxxx
bandwidth 1544
ip nat outside
ip nat pool serialzero 141.155.xxx.xxx 141.155.xxx.xxx netmask 255.255.255.224
ip nat inside source list 1 pool serialzero overload
ip classless
ip route 0.0.0.0 0.0.0.0 Serial0/0
ip route 0.0.0.0 0.0.0.0 Serial0/1
no ip http server
access-list 1 permit 10.0.xxx.xxx 0.255.255.255
access-list 11 permit 10.0.xxx.xxx 0.255.255.255
snmp-server community xxxxxxx RO 10
snmp-server enable traps tty
line con 0
password xxxxxxxxx
line aux 0
line vty 0 4
access-class 11 in
password xxxxxxxxxx
end
vrz-gw#
Thank's a lot,
bye
09-15-2005 05:33 AM
Francisco
There are some things that we do not know that would make it easier to answer your question. First the way that you obscure the IP addresses being used makes it difficult to determine is there is the possibility of a routing issue. Second you do not describe how you are measuring to determine the effect of using both links and what kind of traffic is affected.
But I will make a guess about the problem based on what is in the configuration. I think that your issue is that you specify per packet load balancing. When you do per packet load balancing you introduce the possibility of out of order packets. Some applications are very negatively impacted by out of order packets. They may require executing error recovery logic every time that they see an error/out of order packet, and they may require retransmission of the "bad" packet (and sometimes retransmission of other packets as well).
I suggest that you remove the per packet load balancing, make your measurements again, and let us know if that makes it run better.
Rick
09-15-2005 08:29 AM
mmm, nop, it is not the "per packet load balancing" because I configured that after that problem happened.
and I'm determine the conection speed with this tool:
if you need more information to solve this problem, please, ask to me...
Thanks a lot
Francisco
09-15-2005 10:52 AM
Try ip cef load-sharing universal
09-15-2005 09:27 PM
Well, I haven't used load balance with Cisco router before, but I think you wish to have your two T1 shown as 1 when connecting to outside.
From the article below, load balance at L3 can either be per packet or per dest. But none of them serve your purpose(if my guess is correct).
Read the article and perhaps the multilinkPPP can meet your expectation.
http://www.cisco.com/en/US/products/hw/modules/ps2033/products_white_paper09186a0080091d4b.shtml
Correct me if my comment is not right.
09-20-2005 09:09 AM
mmm, nop, that didn't worked, I already tried cef with load sharing per packet and per destination.
today I tried the multilink ppp but didn't work either...
PLEASE HELP ME!!!! this router is driving me crazy!!!
Thank you very much!
09-20-2005 06:22 PM
Here is a config from one of our routers and this is a working config for multilink PPP
version 12.3
service timestamps log datetime localtime
service password-encryption
hostname xxxx
boot-start-marker
boot-end-marker
clock timezone CST -6
clock summer-time CDT recurring
aaa new-model
aaa authentication login console line
aaa authentication login vty group tacacs+ line
aaa authorization commands 1 vty group tacacs+ none
aaa authorization commands 15 vty group tacacs+ none
aaa accounting exec vty start-stop group tacacs+
aaa accounting commands 1 vty start-stop group tacacs+
aaa accounting commands 15 vty start-stop group tacacs+
aaa accounting connection vty start-stop group tacacs+
aaa accounting connection console start-stop group tacacs+
aaa session-id common
ip subnet-zero
ip multicast-routing
multilink virtual-template 1
ip address 143.115.27.1 255.255.255.0
ip pim sparse-dense-mode
no ip mroute-cache
duplex auto
speed auto
no mop enabled
interface Serial0/0
no ip address
encapsulation ppp
pulse-time 3
no fair-queue
service-module t1 clock source internal
service-module t1 timeslots 1-24
ppp multilink
interface Serial0/1
no ip address
encapsulation ppp
pulse-time 3
no fair-queue
ppp multilink
interface Virtual-Template1
ip address 10.0.27.2 255.255.255.252
cdp enable
ppp authentication chap
ppp multilink
router ospf 100
log-adjacency-changes
network 10.0.27.0 0.0.0.3 area 0
network 143.115.27.0 0.0.0.255 area 27
no ip http server
ip classless
ip pim bidir-enable
ip pim accept-rp auto-rp
logging trap debugging
line con 0
exec-timeout 0 0
password 7 xx
login authentication console
line aux 0
exec-timeout 0 0
password 7 xxx
line vty 0 4
exec-timeout 0 0
password 7 xxxx
login authentication vty
end
09-21-2005 04:00 AM
mmm, I see..... But there tou have only one internet connection.. and, What is the ppp encapsulation??
09-21-2005 04:48 AM
PPP encapsulation is an essential part of multilink. The support for multilink is dependent on all the links using PPP encapsulation so that it can effective bind the group of physical interfaces into one logical interface.
Without PPP encapsulation multilink will not work.
Rick
09-21-2005 07:55 AM
I see... How do I configure that? and is not going to make a conflict with my ISP interfaces? because I don't think that they have PPP encapsulation to....
THANKS!
09-22-2005 07:00 AM
PPP Enacpsulation only works with Cisco routers, so ISP side also needs a Cisco router to get this working. Only other option you have (static route with 2 T1's) may be get 2 frame relay circuits nad do the following.
1. Build the Multi-link frame-relay interface to contain the following:
interface MFR0
no ip address
encapsulation frame-relay IETF
frame-relay lmi-type ansi
4. Build a Sub interface to contain the following:
interface MFR0.1 point-to-point
ip address XXX.XXX.XXX.XXX 255.255.255.252
frame-relay interface-dlci YYY
XXX.XXX.XXX.XXX = WAN ADDRESS
YYY = DLCI
5. Ensure the Serial Interface contains the following information:
interface Serial1/0:0
service-module t1 time-slot 1-24 speed 64
service-module t1 framing esf
service-module linecode b8zs
no ip address
encapsulation frame-relay MFR0
no arp frame-relay
6. Ensure the Serial Interface contains the following information:
interface Serial2/0:0
no ip address
no arp frame-relay
7. Assign a default route statement as below:
ip classless
ip route 0.0.0.0 0.0.0.0 XXX.XXX.XXX.XXX
09-22-2005 08:34 AM
It is absolutely not true that PPP works only with Cisco routers. PPP is standards based and works with just about every vendor's equipment.
I think you have inverted your understanding of HDLC and PPP. Cisco's implementation of HDLC is proprietary and may or may not work with other vendor's equipment but PPP is standards based.
Your suggestion of Frame Relay Multilink is interesting but I feel perhaps more complicated than the implementation of PPP multilink which you preveiously discussed. It would be a very significant amount of change. And it would certainly require the ISP to make significant changes on their end. I believe that the suggestion that you made about implementing PPP multilink is simpler and easier to achieve.
Rick
09-22-2005 08:50 AM
mm, I think u're righ rburts.
But ppp encapsulation, it will work if the ISP end has HDLC encapsulation?
Thats My problem, because if something goes wrong I'm not going to able to connect the router anymore because I use it by remote.
Thank you very much, an forgive my English. I'm Argentinian. I can't talk to much english
sorry...
THANKS!
