atm unable to sync
yayasolenet
Can anybody help me to look into the attachment which is the screen capture of "debug atm event".
Why sometime I get the showtime, sometime I can't. It is connected to adsl2+ dslam.
paolo bevilacqua
Can you send output of "show dsl interface" and mention which exact router type it is.
Thank you for trying to help.
It is cisco 857.
I did not do " sh dsl interface" and I changed it to syslink router which worked.
What does "sh dsl interface" do? To check the Noise Margin, etc?
Cheers,
You need an ADSL FW upgrade on the 857 to connect.
ftp://ftp.cisco.com/pub/access/800
you need 3-0-x
The original fw version is 3.0.14, I upgraded it to 3.0.33.
But there is not much difference.
I think the problem is the line quality.
I connected it to another line, it does work. They are the same isp. Have a look of the working line status. Is the noise margin (10dB) too low? I have no chance to try the command on the one that did not work with cisco but other router.
What is the acceptable figure for cisco router to connect to the adsl2+ dslam?
