Attempting MPLS on my lab... having issues...
tegarant2010
I have two 3620 routers, both running IOS Version 12.3(22) and 3 2507  routers running IOS Version 12.1(20).  I am attempting to setup MPLS on  them and none of the commands show up in the routers at all. I realize that the 2500's may not be able to do MPLS but the 3620's should... any ideas??
I'm sure I'm missing something, I just don't know what it is.. thanks.
Tim
nqtran1979
Most propbably the IOS you've got loaded.
check out the image i've attached ... you'll need at least the SP feature set to run MPLS
