authentication via console
griffith2009
Level 2
Level 2
I have the next configuration:
aaa new-model
aaa authentication login default group tacacs+ local
aaa authentication login no_tacacs local
aaa authentication enable default group tacacs+ enable
aaa authorization exec default group tacacs+ local
aaa authorization commands 15 default group tacacs+ local
aaa accounting commands 15 default start-stop group tacacs+
enable secret xxxxxxxxxxxxxxxxxxxxxxxx
username user password 7 yyyyyyyyyyyyyyyyyyyyyyyyyyyyy
line con 0
If i need to connect through console, the router requested username defined in server tacacs?
if I lose connection to the server tacacs, when i connect via console, the router requested username local "user"?
Maria
If the console is set for default authentication then this line in the config from your original post is the one that will operate:
and what it will do is that it will first attempt to authenticate with the TACACS server (so it will prompt for user name and password, which should be the name and password as configured in TACACS) and if it has lost connection to the TACACS server then it will prompt for user name and password to authenticate the local user name from the config.
Rick
Rick
Richard Burts
Maria
Your configuration includes an authentication named method list of no_tacacs. But you do not show us where (if anywhere) that method is associated with interfaces or lines. And your post shows line con 0 and suggests that there are no config parameters under that line. Is this really the case?
If we accept the posted config at face value then we would believe that when you initiate login at the console that it would attempt to authenticate with tacacs and if it could not communicate with tacacs that it would authenticate with a locally configured user name.
Rick
Rick
Mohamed Sobair
Level 11
Level 11
Adding to Rick's,
1st you need to define which policy u are going to apply under Line consol 0.
this achieved by:
line con 0
login authentication default
or
login authentication (no_tacacs)
2nd u will need to define Tacacs server host and the Key to be used for encrypting the messages between the router and Tacacs server
Mohamed
hi,
Yes in this conf i forget put this lines:
tacacs-server host 1.1.1.1
tacacs-server directed-request
tacacs-server key 7 xxxxxxxxxxxx
That conf was maked by before network administrator.
the method list no_tacacs is not referenced in the config.
I need authenticate in console by tacacs when i have conexion whith tacacs, when that is up, and authenticate with user local when tacacs is down.
With command:
line con 0
I can do this?
Maria
Rick
Rick
