05-27-2008 12:20 AM - edited 03-03-2019 10:06 PM
Team,
Auto Failure is not happening from primary to secondary link , when Flaps are occuring for less than a minute ( such flaps are occuring for 15 times in a hours span ). During this Time Network Auto failure is not working.
Please suggest what should i configure on my both pri/Sec WAN Routers for the Auto Failure to be work ..i have configured EIGRP configured on both Routers.
Any help is highly appreciated.
Akber.
05-27-2008 12:29 AM
Can you post a brief network diagram indicating the connectivity between the routers and the links?
Narayan
05-27-2008 12:38 AM
HI Akber, [Pls Rate if HELPS]
The minimal Fluctuation on Pri in the values of Seconds will not go for the Secondary Fall-back on a General Scenario.
Because for EIGRP, the hold-down Timer has to expire which is 180 in Normal. Reducing the Timers to the minimum is not recommended in design.
Hope I am Informative.
Pls Rate if HELPS
Best Regards,
Guru Prasad R
