Auto Provisioning Cisco Router
Sandro Galletti
Hi' i'm wondering if there any feature for auto-provisiong of the interfaces, connected to ISP.
For example, in Huawei Routers, i can configure Fast-Provisioning, this feature
enable an auto configuration for the ip address point-to-point when the interface receive
a ping from ISP.
For example,  i have a router, with fast-provisioning enabled, then i brought it to a customer, and
i put the adsl cable on atm.
The isp do a Ping from their router to my PTP address, so my router that receive the ping, take the
information of source ip of ping, and set his address to secondary ip of ptp network.
There are anything similar on cisco routers?
adawa
Level 3
Level 3
Hello, Sandro.
There are several Cisco IOS routers that has Auto-Install or setup. Is this for your customers that are home users?
Kind regards.
adawa
Level 3
Level 3
Hello, Sandro.
Kind regards.
It's for my customer :) and when you wrote Auto-Install, you have opened my Mind :)
Now only thing to do is to learn how to do that :).
Thx a lot adawa :)
Sandro Galletti
