AWS VPN tunnels using VRF & BGP
ccallison
I would like to use a single 2901 router to connect to multiple AWS VPCs by using VRF instances.
I have used the base configuration provided by Amazon and a few good tips from this forum on the VRF configuration, but I am trying to take it one step further and use BGP instead of static routing.
When I configured BGP as a non-VRF IPv4 address family, the sessions came up perfectly.
The output of "show ip bgp summary" and "show ip route bgp" are below the configuration text.
Because Amazon may supply me with duplicate IP segments for some of the tunnels, I need to make sure that the tunnel endpoints stay within the VRF and do not end up in the global routing table.
When I reconfigured BGP as a VRF IPv4 address family, the BGP sessions no longer come up.
The BGP section of the config that I changed and the output of "sho ip bgp vpnv4 vrf EU-TEST summ" and "sho ip route vrf EU-TEST bgp" are also include at the end of this message.
Question #1
What do I have to do to get BGP to work as a VRF instance?
Once I get it working, I think that I will have to use VRF export/import statements to get routes to be shared between the VRF routing table and the global routing table.
Question #2:
Is that the correct line of thinking and if so, how do I change the next-hop address when the routes are exported from the VRF routing table?
I thought of adding another VRF loopback address that is in the same IP address space as the inside network of the router and using a "set next-hop" in the export route map.
VRF CONFIGURATION SNIPPETS
ip vrf EU-TEST
 rd 65000:107
 route-target export 65000:107
 route-target import 65000:107
crypto keyring keyring-vpn-0 vrf EU-TEST
  local-address <EXTERNAL-VRF-IP> EU-TEST
  pre-shared-key address <AMAZON-ENDPOINT1> key ***keystring***
crypto keyring keyring-vpn-1 vrf EU-TEST
  pre-shared-key address <AMAZON-ENDPOINT2> ***keystring***
crypto isakmp policy 200
 encr aes
 authentication pre-share
 group 2
 lifetime 28800
crypto isakmp policy 201
 encr aes
 group 2
 lifetime 28800
crypto isakmp profile isakmp-vpn-0
   vrf EU-TEST
   match identity address <AMAZON-ENDPOINT1>
crypto isakmp profile isakmp-vpn-1
   vrf EU-TEST
   match identity address <AMAZON-ENDPOINT2>
crypto ipsec transform-set ipsec-prop-vpn-0 esp-aes esp-sha-hmac
 mode tunnel
crypto ipsec transform-set ipsec-prop-vpn-1 esp-aes esp-sha-hmac
 mode tunnel
crypto ipsec profile ipsec-vpn-0
 set transform-set ipsec-prop-vpn-0
 set pfs group2
crypto ipsec profile ipsec-vpn-1
 set transform-set ipsec-prop-vpn-1
 set pfs group2
interface Loopback107
 ip vrf forwarding EU-TEST
 ip address <EXTERNAL-VRF-IP>
 no ip route-cache cef
interface Tunnel107
 ip address 169.254.254.58 255.255.255.252
 ip virtual-reassembly in
 ip tcp adjust-mss 1387
 tunnel source <EXTERNAL-VRF-IP>
 tunnel mode ipsec ipv4
 tunnel destination <AMAZON-ENDPOINT1>
 tunnel vrf EU-TEST
 tunnel protection ipsec profile ipsec-vpn-0
interface Tunnel207
 ip address 169.254.254.62 255.255.255.252
 tunnel destination <AMAZON-ENDPOINT2>
 tunnel vrf EU-TEST
 tunnel protection ipsec profile ipsec-vpn-1
interface GigabitEthernet0/0
 ip address <EXTERNAL-IP-ADDRESS>
 duplex auto
 speed auto
router bgp 65534
 bgp log-neighbor-changes
 no bgp default ipv4-unicast
 address-family ipv4
  bgp router-id <EXTERNAL-VRF-IP>
  network 10.3.0.0 mask 255.255.0.0
  network 172.18.0.0
  neighbor 169.254.254.57 remote-as 9059
  neighbor 169.254.254.57 timers 10 30 30
  neighbor 169.254.254.57 activate
  neighbor 169.254.254.57 soft-reconfiguration inbound
  neighbor 169.254.254.61 remote-as 9059
  neighbor 169.254.254.61 timers 10 30 30
  neighbor 169.254.254.61 activate
  neighbor 169.254.254.61 soft-reconfiguration inbound
swpl-vpn01#      sho ip bgp summ
Neighbor        V           AS MsgRcvd MsgSent   TblVer  InQ OutQ Up/Down  State/PfxRcd
169.254.254.57  4         9059      15      14        4    0    0 00:01:31        1
169.254.254.61  4         9059      13      16        4    0    0 00:01:32        1
swpl-vpn01#sho ip route bgp
B        10.67.0.0/16 [20/0] via 169.254.254.61, 00:01:38
<BGP address family changed from non-VRF to VRF>
router bgp 65534
 address-family ipv4 vrf EU-TEST
  network 172.18.0.0
swpl-vpn01#sho ip bgp vpnv4 vrf EU-TEST summ
169.254.254.57  4         9059       0       0        1    0    0 never    Idle
169.254.254.61  4         9059       0       0        1    0    0 never    Idle
swpl-vpn01#sho ip route vrf EU-TEST bgp
Gateway of last resort is 208.85.206.193 to network 0.0.0.0
<no routes>
I haven't done what you are trying to do so i may be completely wrong but don't you need to put the actual tunnel itself into the VRF with the "ip vrf forwarding EU-TEST" command under your tunnel interfaces.
The "tunnel vrf EU-TEST" tells the router the tunnel endpoints ie. the source and destination are in the VRF but not the actual tunnel interface itself.
Like i say haven't done your specific setup before so please feel free to ignore.
Jon
10 Replies 10
Reza Sharifi
Not sure why you are trying to use VRF with AWS.  I have a setup with BGP to AWS.
If this is direct connect to AWS, you can simply create a sub-interface for each BGP session with AWS. The way, you don't have to worry about import/export anymore.  It will be in the global config with sub-interfaces and /30 per session.
It's not direct connect, it's VPN tunnels.  You can only have one VPN tunnel per region to a single IP address and I need to connect to three VPCs in a region, so I need 3 VPN tunnels and 3 IP addresses on my side.  Our ISP won't allow us to split up our IP segment, so I have to use VRF for the loopback interfaces.
Ok, I understand it now. Can you try adding "redistribute connected" under address-family ipv4 vrf EU-TEST and see if the BGP sessions come up?
I've been able to get the configuration working and I'm posting my template for anyone's use.  The VPN endpoint,the VPN tunnels and the inside interface that I use as a transit to the LAN are all in the VRF and the BGP connections are in the VRF, so everything is isolated.
I like being able to keep Amazon's 169.254.0.0/16 routes out my network, since I typically include them in bogon lists.
I dumped the configuration to a spreadsheet and made formulas out of all of commands, so now I can recreate it and lay it down with very few changes on any IOS router.
It works perfectly when passing traffic off to another device (for production environments, I planned on having this traffic pass through a firewall anyway), but for the corporate tunnels that don't require as much security, I was hoping to be able to pass the traffic back to the inside interface of the router and use import/export route-maps to pass routes between a global OSPF and VRF BGP process and not use any static routes.
This is still a pretty good tradeoff, though.
Thanks for posting this.
Glad you got it all working in the end.
Jon
Jon
Yes, that may be the missing piece.  I'm going to make some changes and retest.
Yep, that was the missing statement.  BGP popped up right away.  Thanks for the extra pair of eyes, Jon.
No problem, sometimes a second pair of eyes is all that's needed :-)
Glad you got it working.
Jon
ccallison
debugging BGP gave me a few more clues and now with the addition of these commands, the session gets to active but then switches back and forth between active and idle.
router bgp 65534
  neighbor 169.254.254.57 update-source Tunnel107
  neighbor 169.254.254.61 update-source Tunnel207
  neighbor 169.254.254.57 ebgp-multihop 255
  neighbor 169.254.254.61 ebgp-multihop 255
ip route vrf EU-TEST 169.254.254.57 255.255.255.255 Tunnel107
ip route vrf EU-TEST 169.254.254.61 255.255.255.255 Tunnel207
swpl-vpn01#                  sho ip bgp vpnv4 vrf EU-TEST summ
169.254.254.61  4         9059       0       0        1    0    0 never    Active
