azure ipsec asr using aesgcm
hi,
I have problem with using aesgcm for encryption on ipsec tunnels between azure and cisco asr 1001 router. Not working. AES/SHA works ok. Looks like the problem is that I cannot define integrity protocol on ikev2 proposal if aesgcm is used. Has anyone succesifully implemented aesgcm between azure and cisco asr?
br
Giuseppe Larosa
Hello @DraganSkundric87318 ,
I may be wrong but aesgcm does not require integrity check
https://en.wikipedia.org/wiki/Galois/Counter_Mode
Edit:
see also
https://learn.microsoft.com/en-us/dotnet/api/system.security.cryptography.aesgcm?view=net-9.0
Hope to help
Giuseppe
hi,
yes id does not. Point is that ipsec with asr router does not work. ipsec with asa fw works ok, integirity is defined as null on asa ikev2 policy and this setup works ok
---- ASA -----
crypto ikev2 policy 90
encryption aes-gcm-256
integrity null
group 14
prf sha512 sha384 sha256
lifetime seconds 86400
-------- ASR ---------
crypto ikev2 proposal AZURE_GCM
prf sha256 sha512 sha384
group 14
and about that link you've posted. What that means? That azure uses net 9.0 and does not support on-prem cisco ios when using aesgcm?
not all ASR 1k support GCM
Suite-B is not supported on the following hardware platforms:
  • Cisco ASR1001
  • ESP-5
  • ESP-10
  • ESP-20
  • ESP-40
Suite-B has the following cryptographic algorithms:
  • Suite-B-GCM-128-Provides ESP integrity protection, confidentiality, and IPsec encryption algorithms that use the 128-bit AES using Galois and Counter Mode (AES-GCM) described in RFC 4106. This suite should be used when ESP integrity protection and encryption are both needed.
  • Suite-B-GCM-256-Provides ESP integrity protection and confidentiality using 256-bit AES-GCM described in RFC 4106. This suite should be used when ESP integrity protection and encryption are both needed.
  • Suite-B-GMAC-128-Provides ESP integrity protection using 128-bit AES- Galois Message Authentication Code (GMAC) described in RFC 4543, but does not provide confidentiality. This suite should be used only when there is no need for ESP encryption.
  • Suite-B-GMAC-256-Provides ESP integrity protection using 256-bit AES-GMAC described in RFC 4543, but does not provide confidentiality. This suite should be used only when there is no need for ESP encryption.
MHM
vishalbhandari
@DraganSkundric87318 AES-GCM doesn’t require a separate integrity algorithm because it has built-in authentication, which is why Azure and Cisco ASR handle it differently from AES/SHA. On Cisco ASR, when using AES-GCM, you should omit the integrity parameter in the IKEv2 proposal. Instead, ensure that both Azure and ASR are set to use AES-GCM consistently in both IKE and IPsec policies. Also, check that Azure is configured to accept AES-GCM and that there are no mismatches in encryption strength (e.g., AES-GCM-128 vs. AES-GCM-256). If the tunnel still fails, reviewing debug logs on the ASR (debug crypto ikev2) might help pinpoint where the negotiation is breaking down.
