02-01-2006 11:28 PM - edited 03-03-2019 11:38 AM
hello,
i want to make back to back E1 cross cable so what will be the pinout for both the end. In short i want to connect two router back to back using E1. please reply me.
regards
devang
02-02-2006 12:04 AM
Hi Devang,
Connect pins 1,2 of one to pins 4,5 of the other. And also connect pins 4,5 of the first one to pins 1,2 of the other.
Hope that helps - pls rate the post if it does.
Paresh
02-02-2006 01:29 AM
thanks pareshbhai,
ok then it is same as T1 cross cable.
am i right???
02-02-2006 08:53 AM
Yes its the same.
http://www.chebucto.ns.ca//CCN/Technical/Manuals/Max/max6000/gs/cables.htm#21066
Please remember to rate helpful replies!
