Default route selection via OSPF
andtran
The router is connected to two OSPF neighbors via a flat vlan. Each neighbor inject default-route (default originate). Thus, it receives the default-route from each of its neighbor. How can I change the OSPF metric to make one default-route is less favorable than the other (not filtering), but maintain the redundancy.
Otherwise, I use floating static routes.
pkhatri
Level 11
Level 11
Howdy,
On one of the routers, the one you wish to be less favourable, use the following:
default-information originate metric 50
Since the default is a type-2 external with a metric of 20, this second route will be less favourable to it.
Hope that helps - pls rate the post if it does.
Paresh.
the easiest way would be to change the metric of the injected default route with the command:
default-information originate metric x
The lower metric default route will be preferred...
HTH,
GP
ankurbhasin
Level 9
Level 9
Hi Friend,
In addition to all the post this link will give you the details about the command default-information originate for ospf with complete syntax and the usage guidelines
http://www.cisco.com/univercd/cc/td/doc/product/software/ios124/124cr/hirp_r/rte_osph.htm#wp1090223
default-information originate [always] [metric metric-value] [metric-type type-value] [route-map map-name
Ankur
Sorry I did not provide the details. All 15 sites are OSPF-neighbored via a Metro Fiber flat vlan. Two sites inject the defaut-orginate into OSPF. I want load sharing the outbound for internet traffic between the two sites. How can I manipulate the metric for the default-information routes receiving from the two neighbors ?
Floating static routes would work, but it is not the most elegant.
Thanks a lot for all your responses !!
