Back to Back routers
corey.mckinney
I'm having the hardest time trying to do something so simple. I'm connecting two routers (1721 and 2621) together with DCE and DTE cables connected to each other.
What commands do I use to get them to talk? I've got 'Interface UP, Protocol DOWN' on both of them...
Please help!
pkhatri
Level 11
Level 11
On the router to which the DCE cable is connected, issue the following command under the serial interface:
'clock rate '
Choose a bit-rate applicable to your setup.
Hope that helps - pls rate the post if it does.
Paresh
Hi there, what bit rates would people normally set up ?
