Back to Back VRF / Mulit VRF / Global VPN
Dear Expert,
I am planning to deploy Global VPN ( Multi-VRF / NNI ), but the concept is not clear for me.
I have active a new link with my UP Link and configure it as sub-interface.
Now i am going to connect one customer of mine with destination in UP Link network as VPN.
at first what is the required configuration between my PE and CE ? then between PE-UP Link ?
Is it true to enable MB-Ebgp with CE and MPLS ?
Would you please clarify it to me ?
Thanks for your cooperation
Ahmed
6 Replies 6
Giuseppe Larosa
Hello Ahmed,
you haven't clearly described your requirements and you haven't reported a reference to a document describing the solution you are looking at.
However, generally speaking inter VRF communication a.k.a. route leakage between VRFs is implemented by:
a) running MP BGP for all the related VRF address families address-family ipv4 vrf VRF.-NAME
b) playing with route targets  ( route colors) to configure appropriate export ( to MP BGP we could say) and import (from MP BGP route repository to specific VRF)
Between PE and CE you don't need MPLS but just to deploy a logical interface for each VRF. (unless you want to implement a  form of Carrier Supporting Carrier, it is not clear from your post)
MPLS is needed on PE node links directed to the core of the network
Hope to help
Giuseppe
Hello Giuseppe,
Thanks for your reply.
My point is L3VPN between my Backbone and Provider's Backbone.
VPN-A -----CE ------PE ( AS100) ------ PE ( AS200) -----CE----VPN-A
this is what i want to apply, configuration in each segment.
PE ( AS100) ------ PE ( AS200) are directly connected.
Ahmed
Sorry i mean betwwen CE-PE and PE(AS100)-PE(AS200)
Hello Ahmed,
the simplest way to do this is to create a back to back logical link in VRF on your side that connects to VRF on provider's PE node,
This is an Inter AS MPLS L3 VPN scenario and the use of a back to back link is the simplest option A.
It is not really scalable but it is simple to implement.
see
http://www.cisco.com/en/US/docs/ios-xml/ios/mp_ias_and_csc/configuration/12-2sr/mp-vpn-ias-optab.html
Hope to help
Giuseppe
Hi Giuseppe,
Thanks for sharing info.
Concept is clear now.
Do i need a ebgp session with CE ? or simply put the interfaces between PE-CE in VRF ?
CE is directly connected to ASBR(AS111).
ASBR(AS111) ------- static route ------ ASBR(AS222) ??
I will apply the below config:
ASBR:
ip vrf CustomerA
 rd 111:100
 route-target both 111:101
interface gi0/1
 ip vrf forwarding CustomerA
interface gi1/1.1
 encapsulation dot1Q 2
 ip address 10.0.0.5 255.255.255.252 ( 10.0.0.6 at ASBR2)
Please advise.
Ahmed
Hello Ahmed,
Here is document with all three options:
http://blog.ipexpert.com/2010/06/30/introduction-to-interprovider-mpls-l3-vpns/
As document says, you treat ISP as any other location in same VRF. You need to implement some sort of routing between ASBRs (static, OSPF,.... I not sure about eBGP) to exchange routes and accomplish full reachability.
Best Regards
Please rate all helpful posts and close solved questions
Best Regards Please rate all helpful posts and close solved questions
