Backup Entire Flash Contents
bschear
I can backup individual files to an FTP server from Flash but it would be much quicker to copy the entire contents of Flash to the FTP server before I do some upgrades. The Router has quite a few files because it runs CME which would be annoying to backup individually.
pkhatri
Level 11
Level 11
AFAIK, there is no way within IOS to do what you want. You will need to copy the files individually.
Hope that helps - pls rate the post if it does.
Paresh
You can define the following comands in your router and download all files include IOS image from the flash via ftp client program in your PC.
ip ftp username abc
ip ftp password 123
ftp-server enable
ftp-server topdir flash:
