Backup Routing
ergonullu
Hello All
I have 2 2811 routers connected to each other via leased lines.
In Router1 ; I have
Serial 1 with .2 connected to Router 2 Serial 1 with .3 ip address
Serial 2 with .5 connected to Router 2 serial 2 with .6 ip address
ip route 0.0.0.0 0.0.0.0 x.x.x.3 on router1
Question is ..definion of backup situaton
1.On both sides where should I puy backup interface command
2.Should I add another route for backup situation
like ;
ip route 0.0.0.0 0.0.0.0 x.x.x.6 200 (with weight)
Ersin
Richard Burts
Ersin
Using the backup interface command makes it more complex than it needs to be. You should get very satisfactory backup routing by configuring a second static route with the higher Administrative Distance (like your second option).
Rick
Rick
Rick Morris
Level 6
Level 6
one of things I like to do is use equal wieght static routes. This will allow for load sharing and if one goes down the other will still be active. If you only want to use one line at a time use the ip route statement with the weight.
