Backup VPN Connection to Main Building
We currently have a Cisco 1941 at one of our branch offices and it is currently being used to route between a metro Ethernet connection to our main buildings and the branches local subnet. We would like to get an internet connection at the building and use it only for a backup VPN, we would not want any traffic leaving or coming in that interface. We have a card to put in the router to give us another interface to connect to the ISP and we will be purchasing the SEC license to allow us to do a VPN to out ASA at the main building.
What kind of configuration will we need to put in place to accomplish this? I'm assuming that the lack of NAT/PAT rules would prevent traffic from leaving and coming in, or are there other settings that will need to be configured?
We also currently have the gateway of last pointing to the router on the other end of the metro Ethernet line. How do we go about configuring the route out to the internet for the ISP line?
EIGRP is being used as our routing protocol between our various sites. I have seen reference to that not functioning over an IPSEC tunnel. Is that going to be a concern as well?
Any help would be greatly appreciated. Thanks!
10 Replies 10
Richard Burts
I did a project for a customer which was very similar to what you describe, a remote site with an Internet connection which was used only for a site to site VPN back to HQ. So I can say that this can be done. Your question about EIGRP over an IPsec VPN has a fairly simple answer. If it is a pure IPsec implementation with no tunnel interface then there is a problem. The IPsec processes only unicast traffic and since EIGRP uses multicast there is a problem trying to run EIGRP on an IPsec connection. The solution is to use a tunnel with the IPsec. The traditional solution is to use a GRE tunnel with IPsec encryption. For the customer project that I did we used the newer solution which is a Virtual Tunnel Interface. VTI uses a tunnel interface with an IPsec protection profile. VTI is generally a bit easier to configure than GRE since VTI does not require a crypto map as GRE does. But either GRE or VTI would work for you and does support EIGRP and other dynamic routing protocols.
You are correct that not having NAT will eliminate traffic from the Branch LAN going out through the Internet not in the IPsec. But that does not prevent some traffic from the router going out into the Internet without IPsec - particularly traffic to and from the router itself. We had an additional protection in our config which I would suggest to you. We did not have a default route for the Internet facing interface. We had a /32 static route for the tunnel end point on the Internet facing interface and no other route for that interface. So the only traffic going out the Internet facing interface is to HQ.
Rick
Rick
So I will need to create a virtual tunnel interface on the 1941 and the ASA 5515-X. Does the 5515-X support VTI? Do you know of any good documentation off hand for setting up a virtual tunnel interface and the VPN configuration between the two?
I will also set a static route on the 1941 pointing only to the endpoint address of the ASA.
Thank you very much for your detailed reply. It is much appreciated!
I was so focused on the 1941 and the description of the functionality of the remote site that I failed to pay attention to the mention that the main building has an ASA. The ASA does not support VTI and does not support GRE. So your realistic options are much more limited than what I had described. I believe that you will need to do a standard IPsec site to site VPN between the ASA and the 1941. And that takes EIGRP out of consideration for the VPN. I believe that you probably will need to configure floating static routes to direct traffic to the VPN in the event that EIGRP over the Metro Ethernet withdraws its routes due to failure of the Metro Ethernet.
I still believe that you need to be careful about a default route using the Internet. Assuming that you may need to tunnel traffic from the Branch to the Internet over the IPsec VPN I would suggest that your floating static default route use the ASA outside interface as its next hop and that you have a /32 route on the 1941 for the ASA outside interface address.
Sorry that I missed an important detail in your original post.
Rick
Rick
No need for apologies you are certainly very helpful.
So to break it down and make sure I am understanding correctly I will need to do the following:
1.) Create a static route on the 1941 with the destination being only the external address of the ASA and the next hop being the ISP router.
2.) Create a standard IPSEC VPN between the 1941 and the ASA.
3.) Create a floating static route for the gateway of last resort to the internal address of the ASA. (Tunnel endpoint)
4.) Create a static route on the ASA pointing to the networks local to the remote 1941. I'm assuming with higher administrate distances and then redistributed through EIGRP.
Does this all sound correct?
Sounds mostly correct. Here are a couple of points:
- 1) right
- 2) right
- 3) the next hop of the floating static default route is probably the ASA external address rather than its internal address.
- 4) Yes higher admin distance for the static on the ASA will prevent it from being used as long as EIGRP over Metro Ethernet is working. And redistributing on the ASA into EIGRP would allow it to be advertised to the main building.
Rick
Rick
Okay so for number 3 I will create the following static route:
ip route 0.0.0.0 0.0.0.0 x.x.x.x 201 (where x.x.x.x is the external address of the ASA for the VPN tunnel)
So since the policy will be set to encrypt data going to that address it will all be secured correct? Just want to make sure I fully understand what I am doing.
So on the ASA I will need to create the routes in the opposite direction as floating correct? So lets say I use the 192.168.32.0 network at the remote location. If that is the case I will need to create the following static route:
route inside 192.168.32.0 255.255.255.0 y.y.y.y 201 (where y.y.y.y is the external address of the branch router)
I am assuming I will need to set it as an inside route because of the filtering and settings or will I need to will it need to be outside and then have rules set up?
Again, thank you for your help. You have been more than helpful and I appreciate it very much!
The route on the ASA would use outside and not inside. I am not sure what to say about rules set up. There is no need for access policy rules, other than the rules involved in setting up the site to site VPN. For the VPN you will need an access list to identify the traffic to be protected in the VPN, will need a crypto map and tunnel groups, and probably will need a NAT exemption rule (to indicate that the VPN traffic should not be translated - depending on whether your ASA is translating traffic on the outside interface). But no other access rule is needed for VPN traffic.
Rick
Rick
On the 1941 I will have to create a policy for VPN traffic. If my understanding is correct it will match source and destination IP to decide what to send over the VPN. Will this policy make traffic use the VPN and not the EIGRP route over the Metro Ethernet? Or will the policy not take effect until the route is in place to send traffic over it?
When you talk about a policy for VPN that is what is involved in configuring a crypto map and the things associated with the crypto map (access list to identify traffic to be encrypted, ISAKMP policies, Transform set, etc). You will apply the crypto map on the new interface to the ISP. The crypto map will evaluate all traffic going out the interface to the ISP but will not affect traffic going out the Metro Ethernet.
So it comes down to a consideration of how traffic is being forwarded on the 1941. As long as routing is sending traffic out the Metro Ethernet interface there is no impact from the VPN and if routing changes and begins sending traffic out the interface to the ISP then the VPN is involved.
Rick
Rick
Peter Koltl
Level 7
Level 7
I recommend IWAN concept and front door VRF.
