Bandwidt Points
waridtel.com
Can anybody tell me regarding the bandwidth points of 7206-NPE-G2.
Best Regards,
Rahim
attrgautam
Level 5
Level 5
AFAIK there is no difference in the bandwidth points offered on NPE-G2 it is the same 600 points as in the good old NPE-G1
As quoted in http://cisco.com/en/US/products/hw/modules/ps2033/products_configuration_guide_chapter09186a008014cf5c.html#wp1053970
NPE-G1 or NPE-G2
?Left side, bus 1 (slots 1, 3, and 5) and I/O controller (slot 0) has a 600 point maximum.
?Right side, bus 2 (slots 2, 4, and 6) has a 600 point maximum.
?Distribute port adapter bandwidth points evenly across both left and right system slots (buses).
?Do not calculate bandwidth points for an I/O controller if an I/O controller is installed with the NPE-G1 or NPE-G2.
?The NPE-G1 or NPE-G2 Gigabit Ethernet interfaces do not use bandwidth points.
pciaccio
Level 4
Level 4
This attached document describes the requirements for the port adaptors for the 720x routers. Each WAN/LAN PA eata up a certain amount of bandwidth points. This doc explains it....Good Luck.....
