C-3750 LAN Switch Problem ????
afzaalq007
hi
I hav some problem with my LAN Switeches C-3750. i ahve already diccess this thong on the forum. and i want to troubleshoot these LAN SWs. as with the help of below pasted links
http://www.cisco.com/warp/public/473/192.html#subtopic1a.
but befor i trobleshoot i am facing anonther prob i can not get thier Dispaly althouh i have chked all parameters. Consol cable , cable setting etc
but still there is no display
Waiting for ur response
thanks
afzaalq007
I have tried all my possible way .. but still i am unable to get the display oy cisco-3750.
kindly suggest any other technique or method.
When I powered ON the C-3750 it works. and thier FANS are working properly.
When ever I Power UP the SWitch while pressing mode button
It LED status on sys LEd is green
all other LEDs (pps, master stat, dup & speed)show light . and at the en only sys led remain green and thier is no display on my system .. although i have treid diff system and console to quit the dout on cable or sysytem.
waiting for ur replay.
Thanks and regards
What are u r console settings i.e
9600
1 stop bit
8 databits
no flowcontrol
no parity
check this.
Mahmood
hi
I have chked many times and i am using Cisco standard setting , i dont think so this the problem.
Thanks for ur reply.
Afzaal
I have tried some step
)-Verify Switch POST Results
2)-Monitor Switch LEDs
3)-Verify Switch Connections
4)-Monitor Switch Performance
But when tried i have found that there problem on STACk LED so deu to wich all my PORTS are down and i think that is why i am unable to get my Dislpay.
Plzzzz Suggust i have same problem with my 2 c03750 .
