bandwidth 9k when show interface tunnel 0.
syjeon
Hi.
I wonder if when I try to get the output of interface tunnel0. it displays as following.
the tunnel is up and up
bandwidth 9k
My questions is that bandwidth 9k show I issued show interface tunnel 0means that is the real bandwidth is 9k?.
so far I've known, bandwidth is just value when it refers on routing protocol path calculation.
Joseph W. Doherty
Disclaimer
The    Author of this posting offers the information contained within this    posting without consideration and with the reader's understanding that    there's no implied or expressed suitability or fitness for any  purpose.   Information provided is for informational purposes only and  should not   be construed as rendering professional advice of any kind.  Usage of  this  posting's information is solely at reader's own risk.
Liability Disclaimer
In    no event shall Author be liable for any damages whatsoever  (including,   without limitation, damages for loss of use, data or  profit) arising  out  of the use or inability to use the posting's  information even if  Author  has been advised of the possibility of such  damage.
Posting
Is it "real"?  Depends on what's actually supporting the tunnel; likely not.  You're correct it might be used by routing path calculation (or not), might be used by other features too.  This is also true for other interfaces too, i.e. interface bandwidth displayed (or set via a bandwidth statement) doesn't necessarily reflect actual interface bandwidth.
Joseph W. Doherty
Disclaimer
Posting
